20 Most Recent
Eheim 2520800 2080 Canister Filter Complete Media Kit Questions & Answers
Eheim 2080 will not pump
eheim 2080 filter , only 4 months old, will not circulate water. I took it down to clean filter material and hoses . Put it back together and back into tank but it won't circulate the water. I prime it and prefilter fills with water but as soon as you stop priming there is no output from spray bar. I have read and reread booklet 10 times and believe everything is right .....help
Light unit not working after replacing bulbs
Try another wall connection or your wire connection, as well as making sure nothing is wet around the connections, and ultimately nothing is wrong with the entire lighting system.
1/3/2020 8:22:26 PM •
Fish
Answered
on Jan 03, 2020
Fluval chi aquarium light does not turn off, defective switch how do I repair it?
Much too late to help, I'm sure, but the cheapest fix would likely be to add a simple tap switch.When the tap switch is turned off, it cuts the power off and the light will go out. A tap switch is simply an outlet with a switch fitted. Plug the tap switch into the wall, plug the aquarium light into the tap switch and you're set. They're cheap at places like Home Depot, likely half the price of the replacement switch from Hagen, who makes Fluval. Also a great way to make it easy to turn filters on and off without having to pull the cord from the outlet.
12/26/2019 9:05:37 PM •
Fish
Answered
on Dec 26, 2019
How to assemble?
"How to assemble? - Fish"???
Umm, you take the body and stick the marked fins on the sides, top, and back at the appropriate slots then install the batteries and drop it in the tank.
12/25/2019 2:07:17 AM •
Fish
Answered
on Dec 25, 2019
They get plants, algae, and bacteria.
Bacteria in fish tank ?
Bacteria is normal . breaks down ammonia from fish into nitrate.
Nitrate is harmful and requires a water change unless you pump the water through plants google aquaponics.
Algae in fish tank ? buy water snails put in tank
10/22/2019 10:11:28 PM •
Fish
Answered
on Oct 22, 2019
I need aquarium filter for my 300l tank. Would you help me with the choice?
I think, a sponge filter is for you - simple, cheap and effective.
It provides mechanical and biological filtration, once the sponge has grown bacterial colonies. Filters come in a variety of sizes shapes, and pore sizes to adapt them to an almost filtration need. Sponges give excellent results in ponds, saltwater, and freshwater. They can be used as an addition to another filter, such as a canister filter, or as the only source of aquarium filtration - https://great-filter.com/best-sponge-filter/
7/29/2019 10:22:05 AM •
Fish
Answered
on Jul 29, 2019
What kind of filter should I buy for my aquarium?
In
my opinion, power filters are the best.
They are easy to maintain and are also quite economical. The most common style of power filter hangs
on the back of your tank. A siphon will
pull water from the tank, eliminating any bacteria and returning filtered water
back into the aquarium.
6/21/2019 5:15:11 AM •
Fish
Answered
on Jun 21, 2019
Seo agency in London ?
Currently looking for an London
seo london Agency, due to the fact I at the moment dwell in that place, and have alot of labor inside my portfolio of internet sites.
6/5/2019 4:05:33 AM •
Fish
Answered
on Jun 05, 2019
