20 Most Recent Nokia 3110 Classic GSM No Contract Orange Questions & Answers
Faulty charger can you try it on your friends phone to see if charger is working 4
Nokia 3110 Cell... | Answered on Apr 27, 2016
Solution 1:
1. Go to file manager on your mobile
2. In Settings choose system folders,
3. In the System folder, find a file called mmcstore
4. Send the file to your PC using IR/Bluetooth
5. Open the file in Notepad
6. The password you need for your memory card is located within that file
Solution 2:
1. Download and Install FExplorer
2. Insert your card into your phone, without accessing it through the phone
3. Run FExplorer and Open the path C:system
4. Find the file called mmcstore, and rename it mmcstore.txt
5. Copy that file (mmcstore.txt) to your PC and open it in Notepad
6. Your password will be located within that file.
Solution 3:
1. Download and Instal X-Plore
2. Now open the X-Plore and press Zero(0) then check you have marked the
"Show the System Files".
3. After you done the above step now go to the file:
C:/Sys/Data/Mmcstore
4. If you found the above path then press the option "3" to set the Hex-Viewer.
5. Now look the third column you can see the code like ! TMSD02G (c ??"? x???3?3?3?3?3)
Now see the characters between '?' because it is your password 33333.
6. You mayn't able to access the path file:
if you don't set the password for the memory card.
Nokia 3110 Cell... | Answered on Dec 08, 2015
If you have a GPRS data plan with your provider just ask them for setting script to be texted to you.
Nokia 3110 Cell... | Answered on Feb 19, 2015
1234? or 12345??? hmmm flash it ^_^
Nokia 3110 Cell... | Answered on Jul 06, 2014
hi Robert Morgan as far I can see the headset is Wireless so you need to CONNECT the headset to the phone via wifi or bluetooth. hope it helps....
Nokia 3110 Cell... | Answered on Jun 06, 2014
Unfortunately that is a very straightforward message. The applications you're currently attempting to access is not formatted for your particular device. You will not be able to access the application until it's producer makes it readily available for your particular device.
Thanks,
Dish Guy
Nokia 3110 Cell... | Answered on May 19, 2014
Hi if your want to unlock your Nokia 3110 mobile from sim lock to freely use it with any network sim ..Then visit sites like Mobile-Unlocker.com they are providing network unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ...
Nokia 3110 Cell... | Answered on Apr 02, 2014
check your service center number of messages in message setting. It could be change or delete.
Nokia 3110 Cell... | Answered on Mar 23, 2014
theres nothing wrong on your phone settings, its just the speaker itself is broken or wire inside your phone cut loose.. bring it to cell shop and repair or replace it with new speaker.
Nokia 3110 Cell... | Answered on Mar 18, 2014
I am not entirely familiar with this phone but I suspect that you are out of luck in so far as a direct approach is concerned. That being said, contacting customer service for your cell service provider should suffice. There is a record of every call made for the current billing period (I do not know how long after that the records are destroyed) and I do not expect you should have any trouble getting the list. Should you have a specific date, time, and recipient, I think they might even be able to give you the number over the phone after confirming your identity.
Nokia 3110 Cell... | Answered on Feb 19, 2014
Nokia 3110 Classic GSM No Contract Orange Logo
1 questions posted
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
View Most Popular
3110 Nokia
  • 3110 Nokia
Most Popular Question
nokia 3110c contact service problem
  • Cell Phones
