20 Most Recent eMachines E442 E442-v133 15.6" Notebook Amd V140 2.3ghz Cpu 2gb Ram 120gb Hdd W7 Questions & Answers
How to fix no boot device on emachines e442 for free
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
12/19/2018 3:58:56 AM • eMachines E442... • Answered on Dec 19, 2018
I have black screen in my computer, whats the problem?
There is a button in ur keyboard for projector / TV press the button and your screen will come. You may have to press the function key and that button together. That button usually stay with the F keys
10/31/2014 10:15:50 AM • eMachines E442... • Answered on Oct 31, 2014
2answers
Fn f5 toggle not working
You may need to hold down the "fn" key (near the windows logo key) while pressing F5 to get the function key to work as you want it to.
8/8/2014 5:03:25 PM • eMachines E442... • Answered on Aug 08, 2014
Drivers download
Click Start > Go to Store > Search there Drivers.Hope I helped.
10/25/2013 12:06:49 PM • eMachines E442... • Answered on Oct 25, 2013
0answers
Wifi wont turn on
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. If not you may need to turn on the wifi on those devices. Usually those setting can be found in menus like Network Settings. Once it recognizes the network you will need the password if it is required. Just enter that in and you are set. Where you enter the password is usually in the same menu in which you turned on your wifi enabled device. if still no connection Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator. 1. Click Start, type services.msc and hit enter. 2. Locate WLAN AutoConfig service, double click on it to open its properties window. 3. Under General tab, change the Startup type to Automatic and click Start button. 4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
2/18/2013 2:10:32 AM • eMachines E442... • Answered on Feb 18, 2013
I counted 13 quick beeps at startup on an emachines E520. what dose that mean ? how do i fix it please ?
Thirteen quick beeps at startup on an eMachines E520 usually indicate a problem with the laptop's RAM (Random Access Memory). This could mean that the RAM is not properly seated in its slot, or it could be a sign of a faulty RAM module.
Here are some troubleshooting steps you can try to resolve this issue:
Turn off the laptop and disconnect it from the power source.
Remove the battery from the laptop.
Locate the RAM compartment on the bottom of the laptop.
Check to make sure that the RAM module is seated properly in its slot. You may need to remove and reinsert the RAM module to ensure a proper connection.
Replace the battery and turn on the laptop.
If the problem persists, try removing the RAM module and testing it in a different laptop or using a different RAM module in the eMachines E520 to determine if the problem is with the RAM module itself or with the laptop's RAM slot.
If none of these steps solve the problem, it may be necessary to contact a computer technician for further assistance..
3/22/2023 9:07:20 PM • eMachines... • Answered on Mar 22, 2023
How to factory reset a Emachines Etower 633id it boots up but says operating system not found it has Microsoft Windows ME Millennium Edititon (from Windows 2000 Professional)
  1. Boot the computer to the boot menu: To do this, restart the computer and press the appropriate key when prompted to enter the boot menu. On most eMachines computers, this is the "F12" key.
  2. Select the CD/DVD drive as the boot device: Use the arrow keys to select the CD/DVD drive and press the "Enter" key to boot from it.
  3. Insert the Windows ME boot disk: Insert the boot disk into the CD/DVD drive and restart the computer.
  4. Choose the "Start Computer with CD-ROM support" option: When prompted, choose the "Start Computer with CD-ROM support" option.
  5. Run the Windows ME setup program: The setup program should start automatically. Follow the on-screen instructions to install Windows ME.
  6. Format the hard drive: During the setup process, you will be prompted to format the hard drive. Choose the "Full" format option to erase all existing data and perform a complete factory reset.
  7. Install Windows ME: Continue to follow the on-screen instructions to complete the installation of Windows ME.
After the installation is complete, the computer should be in a factory reset state and you can begin setting it up as a new system. Please note that resetting your computer to the factory settings will erase all personal data and installed programs, so be sure to back up any important data before proceeding with the reset.
2/13/2023 2:51:11 AM • eMachines... • Answered on Feb 13, 2023
2answers
How do i remove the bios password i set but forgot. i want to change some settings and cant get through.
Larry picks up a question from 2015 ;>) Larry Ng Feb 07, 2022 no PC model told hopeless If desktop, the jumper on the MOBO marked PW_CLR on most. Never laptops
6/21/2022 8:55:19 PM • eMachines... • Answered on Jun 21, 2022
2answers
My local disk E is missing.
device manager 1 of 10000 model ODD optical disk drives made, each drive made has LIMITS some only do CD ROMS BD is blue ray , FIY if missing or maked with red or yellow errors or shows up as unknown that all means DRIVER IS BAD , wrong or missiong NO PC Told so can not tell you how to fix that, lacking such a key fact . (but is at your oem makers PC support page under DRIVERS) brd-undefined-undefined-0.jpg
6/21/2022 8:52:19 PM • eMachines... • Answered on Jun 21, 2022
Hi! I have an emachines laptop E525.I is not going on
moved you out of monitors and into laptops, only forum. emachines full model not old like this example E525-901G1Mi windows 7 loaded day1.
  • the switch is bad Lid close switch
  • set wrong in power settings.
  • or the driver is missing that makes this switch work.
so why not just assign the sleep mode, to auto sleep then on what does the power button do in settings, set to do nothing or set button to only sleep . (3 choices here) or let auto sleep do the work, set. set to say 5min idle. the switch is inside it deep and if you rip it out as you go there most noobs break 2 or 3 FFC cable jacks and now it is bricked and $300 mobo wrecked emachines or junk grade, made by Acer.com owned now and that maker does NOT have service manuals making service a royal Pain. best is work around the problem as I just told how. or ask any shop to fix it. they do know how.!!!
5/16/2022 1:18:24 PM • eMachines... • Answered on May 16, 2022
2answers
Reset my eMachines eM350-2074 Black Intel Atom N450(1.66GHz)
Larry has the answer. Larry Ng Feb 07, 2022 no reason stated, the OS reloaded, ?that? what does reset mean to you? and why.? (selling PC or PC infected?) what:"? ahhhh a Netbook sold new with XP or W7, lost the install media? page 22 in your manual shows that you must create recovery media day one, new. if not , it is GONE. https://www.emachines.com/ec/en/US/conte... ..
5/4/2022 2:12:26 PM • eMachines... • Answered on May 04, 2022
2answers
I can't get my emachines 525 to start up all i get is operating system wasn't found so what do i do
Check the hdd is setup correctly and set as first boot device. Ensure there is no external drive/usb installed.
4/7/2022 6:31:04 PM • eMachines... • Answered on Apr 07, 2022
2answers
I have a eMachines 525 when I start it up all I get is operating system not found
e525 lapTOP OR? FOR GOT TO TYPE THE "e"????? 2009 MADE? 13 YEARS AGO? 2 causes (of many but 2 are CLASSIC COIN cell is now dead CMOS and boot order lost. or hdd bad the cure is, new coin, and reset bios and set boot order to hdd0 first the hdd must pass smart tests. or all hope is gone foR IT. ask how. that error means boot order wrong or hdd is bad. boot fails missing on hdd is bad HDD 99% the time. NO COIN LASTED 13 YEARS. AND MOST HDD SAME THING. UNLESS PUT IN TIME CAPSULE IN Ln2, CRYRO FREEZED. now the BAD NEWS the COIN cell is soldered down to the MOBO and is not a normal CR2032 it is ML1220 rechargeable listed as 5 year life.(MAKER OF COIN) so you fOUND this PC in a garage sale dead for $1?>???? no history told at all, ever fix old cars. ? emaciates now owned by Acer and Toshiba does this nasty trick "solder down" e525 actual 525-undefined-undefined-0.jpg there it is, in all its glory, lots of screws to get and soldering pen to release it, I cut the wires up top and solder then new coin to top wires. and not touch mobo PADS that is a huge hint there.(do no harm)
4/7/2022 6:30:31 PM • eMachines... • Answered on Apr 07, 2022
REPLACE EMACHINE E644G 0663 WITH A NEW SEAGATE HARD DRIVE
how to do this physically or just putting back a new OS there. or what to buy it. or what what parts are unclear.
  • buy new,hdd, or 100x better SSD
  • install it.
  • install what ever OS you want. w7 -64bit new.
age 2011,
2/7/2022 10:26:39 PM • eMachines... • Answered on Feb 07, 2022
My emachines laptop takes quite a long time to start up. when I press the power button on, the power button turns on but the screen remains black until after 1 hour or more. what could be the problem?
classic case most old PC on earth slow. No PC told at all the model, wow.
  1. hdd full
  2. OS virus infected. N
  3. HDD bad, fails smart test.
  4. memory full, add more or git ride of autoloading apps,
2/7/2022 10:22:38 PM • eMachines... • Answered on Feb 07, 2022
eMachines E442 E442-v133 15.6" Notebook Amd V140 2.3ghz Cpu 2gb Ram 120gb Hdd W7 Logo
9 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • eMachines Computers & Internet
Most Popular Question
drivers download
  • Computers & Internet
