20 Most Recent Emerson EWL3706 37 in. LCD Television Questions & Answers
3answers
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
12/13/2020 4:35:13 PM • Emerson EWL3706... • Answered on Dec 13, 2020
Tv will only go to stand by
hello! Here is a link to the "Troubleshooting" part of the manual. Hope it will help! https://manualsbrain.com/en/manuals/982404/?page=32
9/9/2017 4:47:42 PM • Emerson EWL3706... • Answered on Sep 09, 2017
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
7/11/2017 8:34:39 AM • Emerson EWL3706... • Answered on Jul 11, 2017
2answers
Emerson 37 in LCD Television
the problem can be fixed by replacing the digital main board. if its under warrenty take it in and have it replaced for you.
7/11/2015 10:36:13 PM • Emerson EWL3706... • Answered on Jul 11, 2015
2answers
Green light flashes twice then turns red
Please ignore the first solution as that blink code definition is for a Sony CRT based set, NOT an Emerson.
Carefully examine the LCD panel itself with a flashlight and look for small cracks. Based upon your description of events, I think that the panel is actually cracked. This usually only prevents a picture from showing. The red lights are an indication of an internal problem and the set is in shutdown to prevent further damage.
Without seeing the actual unit, I cannot make a definite diagnosis, but I would initially suspect a power supply problem that may be relatively cheap to fix. If the set is relatively new, I'd invest in a detailed repair estimate. Post the info here from that estimate and we may be able to walk you through the actual repair.
Dan
7/7/2015 10:34:52 AM • Emerson EWL3706... • Answered on Jul 07, 2015
6answers
Won't turn on
one of the inverter transformers has gone bad replace the bad one and the set will work fine ,there are 6 transformers in the 32".
5/15/2015 7:15:36 PM • Emerson EWL3706... • Answered on May 15, 2015
My Emerson 37" hdtv will not stay on keeps going off automatically
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/6/2014 2:36:02 PM • Emerson EWL3706... • Answered on Sep 06, 2014
3answers
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
8/10/2014 3:35:36 PM • Emerson EWL3706... • Answered on Aug 10, 2014
Why does my flat screen have black line and smudge on screen?
If you have a black line on the screen press menu button on emerson tv remote. If line id still there then the lcd screen is bad. If war contact auth servicer. If out of war relace the tv.
5/12/2014 11:18:46 PM • Emerson EWL3706... • Answered on May 12, 2014
My emerson TV shows black and white pictures..what should i do?to make it color
Check the television settings http://www.manualslib.com/manual/47241/Emerson-Av50.html?page=30#manual If Pal or NTSC these are the color systems if it is a mismatch to your broadcaster you won't get color.
5/3/2014 10:43:59 AM • Emerson EWL3706... • Answered on May 03, 2014
2answers
Shuts off
There is a short on the video controller and when it heats up, the circuit opens and disconnects or what we call a short circuit. A technician can locate that point with his/her test equipment and do a repiair.
3/27/2014 3:02:51 PM • Emerson EWL3706... • Answered on Mar 27, 2014
Dish remote codes for Cielo TV
0032,0039,0031 are the codes to check. If you wish to get more codes and other details check: http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
1/17/2014 8:56:53 AM • Emerson EWL3706... • Answered on Jan 17, 2014
Shadow on screen
needs new lcd panel. probably cheaper to replace the tv set.
1/7/2014 11:33:01 PM • Emerson EWL3706... • Answered on Jan 07, 2014
I need a remote code for a Panasonic TV, Model Nr. CT20658 to program my Infinity remote. Thx in advance.
0048,0042,0041. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
12/1/2013 5:05:48 AM • Emerson EWL3706... • Answered on Dec 01, 2013
2answers
WHERE To BUY power boards for emerson 32" FS TV
I had the same problem. Mine gave out in 4 months. Those boards are hard to find right now. Google the the board# BA71FOFO1042 and someone like (buyjimmy.com) I think will sell TV parts. If not, you can fix the board itself like I did. Mine was a bad inverter transformer. If you need the parts# for anything let me know, I have the Service Manual for the TV. Good Luck
9/24/2013 6:03:47 PM • Emerson EWL3706... • Answered on Sep 24, 2013
Emerson EWL3706 37 in. LCD Television Logo
170 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
flat screen black line smudge screen
  • Televison & Video
