20 Most Recent Gateway MX6931 Notebook Questions & Answers
Max memory suported??
4GB
9/7/2011 2:59:01 AM • Gateway MX6931... • Answered on Sep 07, 2011
I have a Gateway MX6931 - the lights come on, fan
replace the memory
12/22/2010 7:22:59 PM • Gateway MX6931... • Answered on Dec 22, 2010
How do I replace DVD burner in Gateway MX6931
kindly turn down the system upside and very near to the DVD BURNER there is a clip that you will have to use your hand to slide either backward or forward then you will push the DVD with your hand out while pressing the clip forward or backward according to the arrow it shows ok the refixing it you dont need to press it down anymore just slide the DVD in and a click sound shows you have drive it home.
5/7/2010 1:49:06 PM • Gateway MX6931... • Answered on May 07, 2010
I just replaced my ac adapter for my gateway lap
Chances are the power jack in the laptop that is to blame. It's common for the solder connections holding the jack to the motherboard to break because of the power plug flexing. One way to check is to keep the laptop steady and wiggle the power plug. If the power indicator flickers, that's what's wrong.
The good news is that this is usually repairable. The bad news is that not all service shops are willing to get into this level of repair. The motherboard needs to be removed from the computer so the connections can be repaired. Sometimes the board needs some mechanical repair as well, and occasionally the only way to fix the trouble is to replace the board. Most shops want to replace the motherboard right off.
Call around to shops in your area and see who's willing to try soldering the board. That is usually all that's needed to get you going again.
2/2/2010 5:29:20 PM • Gateway MX6931... • Answered on Feb 02, 2010
Gateway screen comes up; optical and (new) hard
If you have an operating system disc that came with your computer try putting it is and see if you can load the disc. If you can go to the repair screen after it loads all files. When you are at command prompt type: chkdsk /r
It will try to repair operating system. When done type "Exit" and restart. If you can't load the operating system disc you might be having a graphics card problem. Go to the manufacturer's website and check on their forums for your problem. Hope this helps
8/1/2009 4:08:20 PM • Gateway MX6931... • Answered on Aug 01, 2009
Im trying to replace the dc jack on a gateway
yes you need to pull ALL parts HDD, dvd drive,....
then turn it over and pry loos the cover above the keyboard you should then be able to remove the keyboard
6/20/2009 1:26:54 AM • Gateway MX6931... • Answered on Jun 20, 2009
2answers
Cracked LCD
Usually, yes, the LCD is covered under the warranty. If not, it could cost around $400 to fix.
10/4/2008 1:17:25 PM • Gateway MX6931... • Answered on Oct 04, 2008
I need to factory restore
Not enough information to answer. Need manufacturer and specific model number before we can help. Generally, though, laptops come with one of three ways to restore. 1. The manufacturer supplies a restore disk. This can be a self-booting image of the original load, or it can be an OS disk and an accompanying drivers disk that needs to be installed to restore the unit. 2. The manufacturer provides an application on the drive that the user is supposed to use at the time of purchase to create a set of recovery disks. This application is usually a 1-time-only thing and you cannot make multiple recovery sets with the app, but you can burn copies of the disk(s) you make. 3. The manufacturer places a hidden recovery partition on the hard drive that allows the user to restore the original factory image. There is usually a hotkey combination written into the BIOS that will divert the boot to the recovery sector when pressed at bootup. Some manufacturers offer both options 2 and 3. But if you got a set of recovery disks at time of purchase, chances are there is no recovery partition on the drive. Recovery partitions are nice and convenient until the problem is the hard drive itself. If you can provide a specific model number, we may be able to better determine which type of recovery option(s) are available for you PC.
12/1/2015 6:34:24 AM • Gateway MX... • Answered on Dec 01, 2015
2answers
How do i open flash drive
It should be a memory card reader. Press in gently, but quickly and plastic tray should pop out.
3/3/2014 4:00:36 AM • Gateway MX... • Answered on Mar 03, 2014
El autocad es compatible con laptop gateway
Trabaja con autocad ficheros por medio de programa para reparar archivos .dwgUtiliza http://www.autocad.repairtoolboxx.com/es
6/19/2013 10:44:39 PM • Gateway MX... • Answered on Jun 19, 2013
Why is my screen sideways
Press Alt + CTRL + Down arrow at the same time, this should adjust the screen to the proper setting. A+ certified, network+ certified, MCSE 2003, MCP, 6 years+ in various IT related posittions. Windows 8, Windows 7, Windows XP, Server 2003, Mac OS X, Fedora, Ubuntu.For remote desktop support please visit me at https://www.crossloop.com/RickPoitras
5/27/2013 1:14:02 PM • Gateway MX... • Answered on May 27, 2013
My touchpad is unresponsive
Step 1: Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
2/19/2013 10:43:53 PM • Gateway MX... • Answered on Feb 19, 2013
Itunes wont open
A corrupt iTunes library prevents the iTunes program from opening and prevents Apple device synchronization. According to Apple, the iTunes library must be rebuilt, which resets the library and removes the current content in the media manager. Back up your media prior to recreating the library, as the recreating process erases all content and your Apple device will synchronize with the blank, recreated library and erase the device's information. Insert the DVD-RW disc into the computer's DVD-RW drive, and open iTunes. Click "File," "Library" and "Backup to Disc." Select the iTunes library and playlist backup and click "Next." Eject the disc after the backup completes, and close out of iTunes. Move "iTunes Music Library.xml" from your iTunes folder to the desktop. Right-click "iTunes Library" and click "Delete." Launch iTunes and click "File," "Library" and "Import Playlist." Locate and double-click the iTunes Music Library.xml file. Insert the burned disc into the DVD-RW drive and click "Restore." or Fix iTunes if It Won't Open on Your Computer b> You've clicked and clicked and clicked some more, but iTunes just refuses to launch. A non responsive program is frustrating to any computer user, but especially if all you want to do is listen to some music or download a new album. If iTunes isn't opening, there are many possible causes for this error. None of these fixes will affect your current music collection. Though you may need to tweak or reinstall some software, your MP3s will stay right where they are. Confirm that your Apple device is connected securely to your computer. If you are not trying to access iTunes via an Apple device, or if your device is connected correctly, continue to step two. Configure your firewall to allow iTunes to connect to the Internet. Many firewalls block software programs' ability to get online as a security precaution. This is because some spyware and malware is designed to transmit personal data from your computer. Making iTunes a trusted program within your firewall software is necessary for it to function properly. Create a new iTunes library file. An unstable or corrupted library file can cause iTunes to suddenly quit or not open at all. Recreating a library file is a lengthy process that depends heavily on the operating system you are using. See the iTunes Support page under. http://support.apple.com/kb/HT1451 Reinstall iTunes on your computer. If no other troubleshooting steps are successful, then the fastest way to solve the problem is to start from scratch. Hope this helps. b>
12/26/2012 11:01:23 PM • Gateway MX... • Answered on Dec 26, 2012
I have a Gateway laptop, MX8739, that will not power on
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
11/17/2012 11:49:30 PM • Gateway MX... • Answered on Nov 17, 2012
Trying to remove or reset hdd password, cannot get to bios
Hard drive password is difficult to remove. These WEB sites maybe able to help you. HARD DRIVE PASSWORD UNLOCKING - Purchase http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free) http://www.hddunlock.com/download/ .
9/11/2012 10:43:34 AM • Gateway MX... • Answered on Sep 11, 2012
Gateway MX6931 Notebook Logo
14 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MX Gateway
  • MX Gateway
Most Popular Question
just replaced ac adapter gateway lap
  • Computers & Internet
