20 Most Recent
ASUS G2P Notebook Questions & Answers
Asus screen notting appear when
Please try this: Connect your laptop to a working monitor. Then use the monitor as your temporary monitor. If this works, then the screen in your laptop is broken or damaged. If this still doesn't work, your laptop might be broken. In this case, try formatting it.
thanks.
regards,
longgee
12/27/2010 5:20:06 AM •
ASUS G2P...
Answered
on Dec 27, 2010
Screen cuts out while using it have to use fn and
OkI want you to get the latest video drivers for your unit and install them. Also check for any BIOS updates. This sounds like a driver problem, and pressing those keys, is "Toggling" between External & Internal screens, and each time it is done it "Resets" the driver & video. So we must rule out drivers first. Also disable any screen saver for now.
2/17/2010 3:53:50 AM •
ASUS G2P...
Answered
on Feb 17, 2010
Asus g2p max ram
You got two memory ports. One on the bottom of the unit.The second one is on top of your Notebook. To reach it you have to remove the keyboard. There are three small points on the top of the keyboard to unlock it. Under the keyboard you will find a metal protector with one screw which protects the second ram...
By the way: The Bios only recognizes up to 2 of ram.
System Profile
ASUS G2P
Standard Memory
0 MB (removable)
Maximum Memory
2.0 GB
Slots
2 sockets
System Notes
PC2-4200/5300 DDR2
SDRAM SODIMMs
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
4/1/2009 2:48:34 PM •
ASUS G2P...
Answered
on Apr 01, 2009
ASUS G73jh Start-up Power BUTTON Problem
Hello ,I can take remote access of your system and fix issue for you, one time charges USD 30; pay only if issue is resolved.
Call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number).
My Name is Harry.
Msata asus g55vw
if you're asking "can it be done" then the answer is yes but it is not easy. if your asus is still under warranty, adding an msata drive or RAM on the otherside of the motherboard will void your warranty, if that is not your question, please elaborate.
