20 Most Recent Acer Aspire 3680 Laptop Questions & Answers
2answers
The hard drive crashed so I bought another
If the issue here is the hard drive is not visible, then there is a solution to fix that issue. Want to know? Try to read this one; What to Do if Your Hard Drive Is not Showing up on Windows 11/10/8/7. recover-data-from-hard-drive-wk4es2pqyb0hmoss3fkcatx2-d-0.jpg
6/7/2022 2:34:47 AM • Acer Aspire 3680... • Answered on Jun 07, 2022
3answers
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
12/3/2021 6:59:19 PM • Acer Aspire 3680... • Answered on Dec 03, 2021
14answers
Forgot my windows 7 password
Forgot Windows 7 password? Do you have reset disk? If the answer is yes, directly click "Reset Password" link to reset forgotten Windows 7 password. If not, learn some ways from here: http://www.isunshare.com/windows-7-password/forgot-windows-7-password-no-reset-disk.html
9/7/2021 6:05:02 PM • Acer Aspire 3680... • Answered on Sep 07, 2021
DVD burn
Chances are that your laptop has a CD burner and a DVD rom which only reads DVD's but will burn regular CDs
Hope this helps
2/27/2021 2:02:25 PM • Acer Aspire 3680... • Answered on Feb 27, 2021
2answers
Burning a dvd on an acer aspire 3680 laptop
If you have a dvd burner, you need software to burn dvd's. VSO is good and simple software to use, i think they have a sample.
2/27/2021 2:12:56 AM • Acer Aspire 3680... • Answered on Feb 27, 2021
Latest bios for hp 540
huh?
12/24/2019 10:05:39 AM • Acer Aspire 3680... • Answered on Dec 24, 2019
2answers
Dvd writers for laptops?
What do you mean by dvd writer? Are you talking about a dvd program? What exactly are you trying to do?
12/12/2019 6:10:49 AM • Acer Aspire 3680... • Answered on Dec 12, 2019
2answers
Error Message : insufficient system resources exist to complete the API
boot your system in safe mode by pressing f8 key repeatedly during the booting process then select safe mode and press enter then go to system restore option, and select system restore, then select some previous date where system is working fine, restore it
how do you like the solution please rate it
6/20/2019 6:21:36 AM • Acer Aspire 3680... • Answered on Jun 20, 2019
4answers
DVD / CD - RW Combo
When you say you cannot burn DVD's, do you mean you cannot burn DVD movies or do you mean you cannot burn data files to a DVD?
Burning DVD movies requires specific software to transcode the video and create a directory structure that DVD's players expect.
When you try to burn DVD's does it produce an error? What software are you using to burn?
5/6/2019 9:13:34 AM • Acer Aspire 3680... • Answered on May 06, 2019
2answers
I thought the problem was
Hi, maybe your power adapter, its cable or plug is faulty, maybe some of your friends has the same type of power adapter to test it with your computer. If you have a DC Voltmeter to could check output voltage from your power adapter.
12/13/2018 10:23:26 PM • Acer Aspire 3680... • Answered on Dec 13, 2018
My Acer 3680 laptop can barely get a charge
There is 2 possible problems, 1) the connector on the computer side (motherboard) is damaged and 2) the power cord from the power supply is damaged.
1) you can really a lot about unless you bring it to a computer shop to repair. BUT I would check for #2
2) Go to a computer store like best buy and get a universal power supply that works for your laptop and try it out first. If it works well. then its not #1 problem.
12/13/2018 10:03:18 PM • Acer Aspire 3680... • Answered on Dec 13, 2018
4answers
HOW to check warranty status for Acer?
Click here to access the Acer warranty information page. This site will help you know the warranty status of your Acer machine. Type the serial number of your machine on the system Serial textbox and press Find Serial Number Button. You may locate the serial number of your computer at the bottom of laptop computer.
10/2/2018 8:26:28 AM • Acer Aspire 3680... • Answered on Oct 02, 2018
I have and Acer aspire 3680 laptop,
I would say that the battery is not charging.
2/15/2018 12:29:05 AM • Acer Aspire 3680... • Answered on Feb 15, 2018
How to decrypt a file encrypred with Acer eData
the short answer to your question is "No", in order to decrypt any file depending on the encryption process implemented, you would need either "a private key" or both parties will need the "public" and the other should have the "private"; I advice you not to have any one scam you into saying that this is possible because unless you have a similar system that was using this type of encryption it might not work. sorry for your loss!
2/5/2018 2:48:25 PM • Acer Aspire 3680... • Answered on Feb 05, 2018
2answers
Help
please post the make and model of your laptop, so I can see if I can help you dig up the network driver for this particular model...
Are you running Vista Home? Is it an Aspire 3680 Laptop?
Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook
11/29/2017 11:34:17 AM • Acer Aspire 3680... • Answered on Nov 29, 2017
Magic Jack install problem
this might help you out.... Magicjack install problem Google Search
10/25/2017 3:00:15 PM • Acer Aspire 3680... • Answered on Oct 25, 2017
I have an acer aspire 3680 laptop with a broken power button
Ok, it seems that this is a pretty common issue. I found a youtube video showing how to get around this. I watched some of it, the guys seems pretty competent. however, you might not be comfortable taking this thing apart or doing what he is doing. However, it is a relatively simple thing to fix for a competent repair person and I looked up new power assembly and they run around $25 on ebay. Here is the link for the video I found: https://www.youtube.com/watch?v=YMprUUBvlmo There were a couple of other videos also that I didn't watch. However, if you just need this thing to work for a while and you intend to replace it in the near future and just need to get by for a short while, this should work. If you intend to keep this long term you might want to take it to a computer repair shop. Good luck. hope this helps.
9/27/2017 3:23:49 PM • Acer Aspire 3680... • Answered on Sep 27, 2017
I have a black screen and in the upper left corner
the hard disk is bad you have to replace it
8/14/2017 9:13:38 AM • Acer Aspire 3680... • Answered on Aug 14, 2017
2answers
Wireless switch is broken on my acer aspire 3680.
No you need switch,if you use a tiny screw driver you can turn it on with that if its just the plastic peice thats broke.use the screw driver to slide the mechanisam
1/7/2017 11:54:35 PM • Acer Aspire 3680... • Answered on Jan 07, 2017
What is TV-ConfigMgr Err 31
Try going to: http://support.microsoft.com/kb/270008 to fix this issue. For other IT solutions try visiting: https://www.youtube.com/user/jrlake2414?sub_confirmation=1 If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
3/22/2016 2:26:16 PM • Acer Aspire 3680... • Answered on Mar 22, 2016
Acer Aspire 3680 Laptop Logo
1,971 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
desktop doesnt appear computer
  • Computers & Internet
