20 Most Recent Acer Aspire 5100-5033 Notebook Questions & Answers
Acer aspire 5100-3583 boots, screen is on, but
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
12/11/2017 9:37:10 AM • Acer Aspire... • Answered on Dec 11, 2017
2answers
Acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
12/3/2013 5:00:46 PM • Acer Aspire... • Answered on Dec 03, 2013
Malfunction keypad to start
can you please elaborate on the problem you are having??You can reinstall drivers and applications using recovery partition.start/programs/recovery/reinstall application drivers
4/15/2013 3:40:26 AM • Acer Aspire... • Answered on Apr 15, 2013
Acer aspire 5515(laptop) screen is black turns on screen stayscompletly black...no acer logo nothing just a black screen. power button comes up green u can hear the fan and harddrive start up
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
2/2/2013 4:33:01 AM • Acer Aspire... • Answered on Feb 02, 2013
I am trying to use
Close down any open applications on your computer.
Press the "Alt + F10" keys on your keyboard. This will open the eRecovery Management system on your computer.
Enter the password for the recovery system. The password will be the one you assigned when you set up the laptop or the default. The default is six zeros, or "000000."
Select "Recovery Options" from the start screen on the management system. Select the "Next" button to continue.
Choose "Reinstall Applications/driver" from the Options provided and press the "Next" button.
Select "Driver" and "Camera" from the Drivers screen. Move to the right side of the window and choose "Install Camera Driver Now."
Let the laptop reboot and install the driver. I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
9/15/2011 1:27:56 AM • Acer Aspire... • Answered on Sep 15, 2011
5answers
Acer Aspire 4520 display off suddenly without warning
please clarify this sequence of events: "on AC power,it seems to be working fine. But the problem occurs when I try restart it on the next morning"... was it restarted next morning on AC power or battery...which one?
7/6/2011 8:56:03 AM • Acer Aspire... • Answered on Jul 06, 2011
How do i get the
It depends on the drive model but there is usually a 'button' on the drive door: while the unit is power up, just press it to open the cd/dvd drive bay.
Hope it helps.
4/27/2011 3:03:55 AM • Acer Aspire... • Answered on Apr 27, 2011
I have an Acer Aspire
Welcome to Fixya. May i know the steps that you did when you do the password reset? did you open the system? If the system shuts itself off can you please remove the battery to drain the power for 2-3 minutes then plug it back in to see if it will works. You can also remove the battery and try to run the computer by just using the AC adapter.
Please provide the information that is needed to fix the issue. Thanks
4/14/2011 11:52:31 PM • Acer Aspire... • Answered on Apr 14, 2011
My webcam is not working
Try this webcam technical support guide for help in restoring your webcam. Your driver may be disabled or corrupted.
1/23/2011 4:45:03 PM • Acer Aspire... • Answered on Jan 23, 2011
It reads CD-R, but not
try cleaning the lens with a soft cotton cloth
12/7/2010 6:37:41 AM • Acer Aspire... • Answered on Dec 07, 2010
I have an Acer CS6530
Hello, and thanks for using FixYa.
If your computer is stuck and you just want to get it working again, and you can't even restart it right now, then just hold down the power button for around 15seconds until it powers off and then turn it back on and it should work normally.
If your still having trouble after that, are you using somekind of a USB computer to computer transfer cable?
10/25/2010 5:43:40 PM • Acer Aspire... • Answered on Oct 25, 2010
How to increase notebook battary backup
Hi, the problem is you cant without buying a new battery but what they dont tell you and should tell you is this.
when your using your notebook off the mains you should remove the battery as this keeps it working at its best only use the battery when you need to and after give it a full charge then leave it out whilst you use the notebook on the mains.
leaving the battery in will sap the life out of the battery and you will end up needing a new battery every few months as it just wont hold the charge as it did when new.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
9/21/2010 2:47:21 PM • Acer Aspire... • Answered on Sep 21, 2010
4answers
Acer Aspire 5100 Notebook
need computer keyboard drivers and/or layouts. Additional information and links to comptuer keyboard drivers and layouts.
Keyboard, Mouse, and other input related links Linking you to various locations on the internet about computer input devices.
Information about the AT and PS/2 port This port is commonly used for a computer keyboard. ... This port is used to accept input devices such as the Mouse and Keyboard.
A20 error Issue related to the keyboard and/or keyboard controller. Solution:. Ensure the keyboard is connected to the proper port on the back of the computer.
Additional information and help with installing computer hardware. PC computer keyboards PC computer motherboards PC computer mouse PC computer power supply PC computer memory ... CH000449, Installing a computer keyboard.
NTOSKRNL.EXE is missing or corrupt. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the
Read instructions/Good Luck, Please dont for get to Vote/Thank You.
9/5/2010 1:11:51 PM • Acer Aspire... • Answered on Sep 05, 2010
My acer battery don't charge.
The issue might be due to various reasons.
Visit the below weblink for more information:
http://notebook-solutions.blogspot.com/2009/05/battery-does-not-charge-or-will-not.html
9/3/2010 1:49:50 PM • Acer Aspire... • Answered on Sep 03, 2010
KEEPS REBOOTING THEN SHUTS DOWN.
Boot into Safe Mode, (keep tapping F8 on the keyboard while it boots up) and delete or uninstall recently installed or if possible, restore your system. To do this, [in the Safe Mode] click "Start" > "All Programs" > "Accessories" > "System Tools" > "System Restore".
If you can't boot into Safe Mode, you'll need to recover the system using the Recovery Disk or you may need to repair or reinstall the Windows, i.e. Operating System.
Good luck.
Thanks for using FixYa.
8/22/2010 2:09:59 PM • Acer Aspire... • Answered on Aug 22, 2010
I have an Acer 5100-5033 laptop with Vista. I
Click on this link and carefully read the information:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;314060
3/30/2010 11:50:26 PM • Acer Aspire... • Answered on Mar 30, 2010
No display from acer aspire 4520
sir maybe your lcd is defective or video card try put another monitor in your laptop
2/9/2010 4:28:28 PM • Acer Aspire... • Answered on Feb 09, 2010
I uninstalled the CD/DVD software on my Acer
You probably uninstalled the cd driver. I can provide you the download links but I need to know the operating system.
1/17/2010 2:03:25 PM • Acer Aspire... • Answered on Jan 17, 2010
2answers
I bought an acer aspire
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena24
1/17/2010 1:59:07 PM • Acer Aspire... • Answered on Jan 17, 2010
Acer Aspire 5100-5033 Notebook Logo
Popular Tags
95 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire
  • Computers & Internet
