20 Most Recent
Dell XPS M1210 Notebook Questions & Answers
Dell 210 xps dislays ! ! 0xc0000034 ! ! 271/100931
This error is a registry error and it is with Windows 7 I presume.This will take a Windows Tech at Microsoft to get a solution. The registry is not to be tampered with unless you a very learned in this area.I don't recommend giving instruction to anyone who is not familar with the registry.My recommendation is to call Microsofts tech support.It looks as though the mail file for the SP1 file is corrupt and will not load the dynamc link library for the Outlook or Outlook expess ( SP1 = Service Pack 1)
Hi I have a Dell xps M1210 notebook the screen
the problem you video chip is work of try soldering it with a rebaldiung calor and ready it works again it hapened wen you install a windows version with 64 bits aceleration change all it and you noteboock are work again fine vote please
Hi I just purchased a new screen back cover for my
replace with the same number couse some came in lcd and the news come in led but some come left side and others rigth side te conector this is the problem check the number of sceen ans then change it for the remplace or original
I have a dell xps
first wen the prompt apaer in the screen push many times key F12 then the prompt mode is say to you if you want to begin start in hdd or dvd or usb or net you chost dvd or cd boot and ready vote please
How can i change the
akip all the screews then cover down open here in rigth side see the batery disconect it for a few seconds and then put ir again and ready some times only with the tap of the memory can see it battery remplace it too
Windows xp not connecting to internet
Chek first the network status in control panel this go to have clear numbers in to the protocol ip adreess just like it 0.0.0.0. but if this is clear go to my PC and in to the direcction of my pc put it www.homepage.com and if this work try install exeplorer again or googlechrome
My wireless on my m1210 not working
First chek the network status check the ip adreess is clear 0.0.0.0. and then try again if the network ip have some numbers 198.254.0.1 etc your wirles never gona work try it first
Edit Bios System Data
To begin go to mode safe start then in to the add and put programs clear all video contolers and then restart the lap then it go to begin normal but in the start it want the video driver put the default and ask the real video driver of this but you machine is got to work again nomaly witout vifeo drivers please vote
