20 Most Recent Alcatel Ot-255a Aqua Qwerty Key Board Phone For Simple Mobile Service W/sim Card Questions & Answers
I have alcatel onetouch 813f IMEI code 860487010950820 please i need NETWORK KEY
Fixya does not assist in the breaking of a phone's security nor provide assistance to do so.
1/19/2024 7:05:55 AM • Alcatel Cell... • Answered on Jan 19, 2024
Mms viaero
To set up MMS and internet on your Viaero Alcatel phone, you'll need to enter specific APN (Access Point Name) settings. Typically, you can find these settings in the 'Network & Internet' section of your phone's settings menu. If you're unsure of the exact APN details for Viaero, I recommend checking their website or contacting Viaero customer support for the most accurate information. They should provide you with the necessary data like the APN name, username, and password to configure your phone correctl
12/25/2023 1:29:37 PM • Alcatel Cell... • Answered on Dec 25, 2023
Alcatel phone showing message PLS. REG H/5 , need solation
Here is a couple of answers; https://www.fixya.com/support/t23762460-alcatel_mobile_getting_message_as_pls
12/18/2023 1:02:50 PM • Alcatel Cell... • Answered on Dec 18, 2023
2answers
TCL Tracfone | Alcatel My Flip 2. Unlock code for Tracfone Alcatel Flip 2.
The Unlock code is the one that you or the previous owner put on it. There is no way to know what code you put on it. The only way to fix this is to do a Factory Reset and scrub it clean of all data and reload the operating system clean with no lock code.
How to Reset an Alcatel Phone: 11 Steps (with Pictures)
wikiHow https://www.wikihow.com > ... > Cell Phones 11 steps 1. Turn off your Alcatel phone. Tap and hold the Power button until the screen shuts down. When the screen completely fades to black, then it is already off ... 2. Press and hold the pound (#) key and Power button at the same time for about 3 to 4 seconds. You will be prompted that all the data will be deleted. If ... 3. Select "Yes" to delete all data. Use the phone cursor on your keypad and scroll down to the "Yes" option. Press the OK button to select it. The OK button is ...
How to Perform Hard Reset Tracfone Alcatel A206G Flip ...
TracfoneUserManual.Net https://tracfoneusermanual.net > hard-reset-tracfone-al... Hard Reset Alcatel A206G · Make sure to turn off the phone first. · Press "Power button" and "*" button for a couple of second. · A warning will show up asking if ... .
8/5/2023 4:35:45 PM • Alcatel Cell... • Answered on Aug 05, 2023
How to answer Alcatel flip phone when flipped open only?
Alcatel GO FLIP V - Answer Options
Verizon https://www.verizon.com > ... > How to Use 5 steps 1. From the main screen, select Menu. Utilize the 5-way navigation pad to highlight and press the OK button to select. 2. Select Settings. 3. Select Call Settings.
Alcatel GO FLIP User Guide
T-Mobile https://www.sprint.com > alcatel > documents PDF Call key. Launches call log from idle screen. Back/clear key. Returns you to the previous screen, or close a dialog box, options menu. End/power key. 127 pages
4/6/2023 1:21:26 AM • Alcatel Cell... • Answered on Apr 06, 2023
How to set Alcatel flip phone to receive call when flipped open?
4/6/2023 1:18:56 AM • Alcatel Cell... • Answered on Apr 06, 2023
My Alcatel one touch asking for Network key when I insert my simcard,how do I get it
The network key is a code that is used to unlock your phone's SIM card for use with a specific network carrier. If your Alcatel one touch is asking for a network key when you insert your SIM card, it means that your phone is locked to a particular carrier, and you need to get the unlock code from the carrier or a third-party provider. To get the network key, you will need to contact the carrier that the phone is locked to and request the code. If you have completed your contract with the carrier, they may provide you with the code for free or for a fee. You will need to provide them with your phone's IMEI number, which is a unique identifier for your phone. If the carrier refuses to provide the network key or you don't want to pay the fee, you can also try third-party providers. These providers can unlock your phone for a fee, and they may provide you with the network key. However, be cautious when choosing a third-party provider and make sure they are reputable and reliable. Once you have the network key, you can enter it into your phone when it prompts you to unlock the SIM card. To do this, go to the phone's settings, then to the network settings, and look for the option to enter the network key. Enter the code, and your phone should be unlocked and ready for use with your SIM card.
3/11/2023 6:59:33 PM • Alcatel Cell... • Answered on Mar 11, 2023
Why won't the back button work on my Alcatel pxi theatre
I admire this information for the well-researched content and excellent wording. I acquired so involved in this material that I couldn't stop reading. I'm impressed together with your work and skill. Thanks so much. wedding flip flops for guests
3/11/2023 1:04:14 PM • Alcatel Cell... • Answered on Mar 11, 2023
2answers
Forgot password on alcatel one touch p310
Hi there again. Epson lx350.i replaced main board only to find out later the one pin not working is actually in a fired position until when I switch machine off is when the pin goes back.please assist If I understand correctly, you are saying that after replacing the main board in your Epson LX350 printer, you have found that one of the pins is not functioning properly and it only resets when you switch the machine off. In this case, it's possible that there is an issue with the connection between the pin and the main board or the pin itself may be damaged. Here are some steps you can take to troubleshoot the issue:
  1. Check the connection between the pin and the main board. Make sure that the pin is securely connected to the main board and that there are no loose connections.
  2. Inspect the pin itself for any physical damage or signs of wear and tear. If the pin is damaged, it may need to be replaced.
  3. Check if the pin is properly aligned with the other pins on the main board. If it is misaligned, this could cause the issue you are experiencing.
  4. Check if there are any firmware or software updates available for your printer. Sometimes, updating the firmware or software can fix hardware issues.
If none of these steps resolve the issue, you may need to contact Epson support for further assistance or consider consulting a professional technician to diagnose and fix the problem. My seca 813 only showing STEP OFF AND STOP massage cannot reset ?? If your Seca 813 is only showing the "STEP OFF" and "STOP" messages and is not responding to any commands, it is possible that there is a problem with the scale's sensors or the internal circuitry. Here are some steps you can take to troubleshoot the issue:
  1. Make sure that the scale is on a flat and stable surface. If the scale is on an uneven surface or is wobbling, it may not be able to take accurate readings and could display error messages.
  2. Check the scale's batteries. If the batteries are low, this could cause the scale to malfunction. Replace the batteries with fresh ones and try turning the scale on again.
  3. Reset the scale. Some scales have a reset button or function that can be used to clear any errors or malfunctions. Refer to the user manual for instructions on how to reset your specific model of scale.
  4. Check the scale's sensors. Over time, the sensors on a scale can become dirty or worn, which can affect their accuracy. Clean the sensors with a soft cloth or brush and see if this resolves the issue.
  5. If none of the above steps work, you may need to contact Seca support or a professional technician for further assistance. They may be able to diagnose the issue and recommend a repair or replacement if necessary.
Forgot password on alcatel one touch p310 - Alcatel Cell Phones If you have forgotten the password for your Alcatel One Touch P310 phone, you can try the following steps to reset the password:
  1. Turn off your phone.
  2. Press and hold the Volume Up button and the Power button at the same time until the recovery mode screen appears.
  3. Use the Volume buttons to scroll down to "wipe data/factory reset" and press the Power button to select it.
  4. Scroll down to "Yes" and press the Power button to confirm.
  5. Wait for the reset process to complete. This may take a few minutes.
  6. Once the reset is complete, use the Volume buttons to select "reboot system now" and press the Power button to restart your phone.
  7. Your phone will now be reset to its factory settings, which means that all data and settings, including the password, will be erased.
Note that this process will erase all data on your phone, so make sure to backup any important data before proceeding. If you are unable to reset the password using this method, you may need to contact Alcatel support or a professional technician for further assistance.
3/6/2023 7:50:46 AM • Alcatel Cell... • Answered on Mar 06, 2023
Water inside the alcatel screen
Total loss as water will have also damaged the battery and all the electronics inside.
2/24/2023 10:33:44 PM • Alcatel Cell... • Answered on Feb 24, 2023
On Alcatel A206G flip phone, the screen shows INSERT SIM! error code with SIM installed.
Yes, you can try to back up your contacts from the phone before replacing it. You can use a third-party software such as dr.fone - Phone Backup & Restore to back up your contacts from the phone. This software is available for both Windows and Mac computers.
2/22/2023 10:52:33 PM • Alcatel Cell... • Answered on Feb 22, 2023
Help codes for Alcatel modem
Unfortunately, I cannot provide you with the RCK and NCK codes for your Alcatel modem. These codes are specific to your device and are not publicly available. You will need to contact your service provider or the manufacturer of the modem to obtain these codes.
2/22/2023 10:32:33 PM • Alcatel Cell... • Answered on Feb 22, 2023
Hi, my incoming calls are going to messages and volume on incomings calls is very low
If your incoming calls are going to messages and the volume is lower than usual, it could be due to a problem with the phone settings. Try checking the volume settings on the phone, and make sure the volume is not turned down too low. Additionally, you may need to check the settings for your phone's voicemail, and make sure that your voicemail is not set to kick in after a certain amount of time. If these settings don't help, then you may need to contact your phone's manufacturer for further assistance.
2/4/2023 5:52:23 AM • Alcatel Cell... • Answered on Feb 04, 2023
Does my Alcatel GO FLIP 3 have do not disturb? Something happened and my phone will not ring anymore. I must have changed something and I don't know what?
Question edited for clarity and correct name of the phone. Question moved from Land Phones to Alcatel Cellphone. The A3 has Do Not Disturb, but the Flip doesn't. Your phone is very basic. Here is the manual https://www.metrobyt-mobile.com/content/dam/mpcs/faqsandsupport/alcatel/Alcatel-GO-FLIP-3-UserGuide.pdf So not ringing is likely caused by turning the volume down to off. https://www.google.com/search?q=alcatel+go+flip+3+not+ringing ..
10/19/2022 11:16:28 PM • Alcatel Cell... • Answered on Oct 19, 2022
Alcatel Ot-255a Aqua Qwerty Key Board Phone For Simple Mobile Service W/sim Card Logo
3 questions posted
Top Alcatel Cell Phones Experts
NOEL
NOEL
nexrad_chris
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Alcatel Cell Phones
  • Alcatel Cell Phones
Most Popular Question
please activate alcatel ot 255 input
  • Cell Phones
