20 Most Recent Craftsman 3/4 Hp Garage Door Opener System Belt Drive Motorhead Only Questions & Answers
3answers
How to fix my garage door opener?
I'm assuming you mean that it won't close, only open? If that's the case then your eye beams may need to be adjusted. The wall button can override the sensors whereas the remotes can not.
4/8/2019 11:05:32 AM • Craftsman 3/4 Hp... • Answered on Apr 08, 2019
The door will not close and light flashes 5 times there are no obstructions can i extend trvel time this is a one piece door
Don't know what make of opener you have, but make sure the eyes a pointing at each other.. On a Chamberlain product you should have one amber and one green. On a genie you should have a solid red light
1/8/2016 6:24:47 PM • Craftsman 3/4 Hp... • Answered on Jan 08, 2016
Remote will not open the door unless with 5 feet or less.tried new batteries and new remotes.same prob
Add a wire extension to the motor set antenna.
10/31/2015 5:17:15 PM • Craftsman 3/4 Hp... • Answered on Oct 31, 2015
Put up the opener but when we plugged it in we have nothing?
[PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
www.liftmaster.com/.../en.../tucmanuals/114A3044.pdf Chamberlain GroupThe Chamberlain Group, Inc. 845 Larch Avenue. Elmhurst ... Please read this manualand the enclosed safety materials carefully! ? Fasten the manual near the ...
9/3/2015 1:48:03 AM • Craftsman 3/4 Hp... • Answered on Sep 03, 2015
2answers
Garage door opener won't work
Motor has overheated; the motor unit does not operate or trolleyis stuck on stop bolt = Motor unit hums briefly; RPM Sensor =Short travel 6-8" (15-20 cm).• Unplug unit to reset. Try to operate motor unit, check diagnostic code.• If it is still flashing 5 times and motor unit moves 6-8" (15-20 cm), replace RPMsensor.• If motor unit doesn't operate, motor unit is overheated. Wait 30 minutes andretry. If motor unit still will not operate replace logic board.
4/1/2015 6:37:48 PM • Craftsman 3/4 Hp... • Answered on Apr 01, 2015
2answers
Newly installed garage door opener won't go up completely
check that none of the springs are broken. can you manually push it up the rest of the way?
2/18/2015 3:17:45 PM • Craftsman 3/4 Hp... • Answered on Feb 18, 2015
Garage door problem
If it went all the way down, then "bounced" and went all the way back up, it's not the sensors. You need to check your limits. For some reason the door is going past the limits then the force is telling it that it is pushing too hard so it runs back up when it hits the ground. Clean your eye beams and the bottom of the door (some times leaves will stick and cross the eyebeam as it gets almost closed) just to make sure, but I would try resetting the limits or verify the limit switches are not broke, which can sometimes happen.
2/18/2015 2:21:29 PM • Craftsman 3/4 Hp... • Answered on Feb 18, 2015
Why is the the sensor light is yellow on my craftsman garage door opener?
Because you plugged it in and wired it properly.
1/20/2015 8:35:45 PM • Craftsman 3/4 Hp... • Answered on Jan 20, 2015
Why is the sensor light yellow on my craftsman 3/4 hp garage door opener?
Because you have power to it! If properly aligned, the other one will be green.
1/20/2015 8:35:23 PM • Craftsman 3/4 Hp... • Answered on Jan 20, 2015
My garage door opener will open and close on its own
Someone may have the same frequency in the neighbourhood.
12/22/2014 5:36:59 AM • Craftsman 3/4 Hp... • Answered on Dec 22, 2014
Why wont my 3 remotes (hand held & factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain drive
It could be that your door is binding on the way up and so it stops automatically. Try releasing the emergency pull cord and move the door up and down by hand to see if it is binding, probably near the bottom. The track may be misaligned or there could be something rubbing against the door.
12/22/2014 4:45:10 AM • Craftsman 3/4 Hp... • Answered on Dec 22, 2014
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES. GOOD LUCK STEVE
12/15/2014 7:39:11 PM • Craftsman 3/4 Hp... • Answered on Dec 15, 2014
I have a problem with the hand held remotes working on my garage door working
Look at the opener to see if you can see the small wire dangling form it. That is the antenna. Stretch it out and point it down for maximum range.
8/18/2014 4:53:43 PM • Craftsman 3/4 Hp... • Answered on Aug 18, 2014
Craftsman 3/4 hp garage door opener
not sure, but see the users manual here:http://www.manualslib.com/manual/32293/Craftsman-139-5399.html
3/10/2013 9:20:26 AM • Craftsman 3/4 Hp... • Answered on Mar 10, 2013
Learn
press the learn button on the motor, then you have 30 seconds to set the button you wish on the remote. make sure to do it within 30 seconds
3/10/2013 9:14:54 AM • Craftsman 3/4 Hp... • Answered on Mar 10, 2013
Evrytime i try to close my garage door i have to keep the button pressed
there is a problem with the sensor, when you let go of the button it thinks something is obstructing the path
3/10/2013 9:11:47 AM • Craftsman 3/4 Hp... • Answered on Mar 10, 2013
Garage opener message "door moving"
3/10/2013 9:09:22 AM • Craftsman 3/4 Hp... • Answered on Mar 10, 2013
Craftsman garage door opener
does the door open and close?
3/10/2013 9:07:25 AM • Craftsman 3/4 Hp... • Answered on Mar 10, 2013
2answers
Garage door won't close when it's cold outside
Control board has thermal issue. Bad solder joint that contracts when cold could be the culprit. Take out board and carefully resolder every ****** connection on board.
4/3/2019 9:08:10 AM • Craftsman... • Answered on Apr 03, 2019
The opener on the wall just make a sound but the door won't go up or down
You have a gear kit broke.
6/8/2015 7:56:54 PM • Craftsman... • Answered on Jun 08, 2015
Craftsman 3/4 Hp Garage Door Opener System Belt Drive Motorhead Only Logo
Popular Tags
22 questions posted
Top Craftsman Building Materials Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Building Materials
Most Popular Question
fix garage door opener
  • Building Materials
