20 Most Recent
Whirlpool LGR8648L Gas Dryer Questions & Answers
Whirlpool gas dryer turns on drum spins exhaust is
- Changing from 3 to 4 wire hookup on a electric dryer
- Door switch replacement help for a common door switch
- Dryer basics - Venting problems and power supply
- Dryer basics - timers and how they work
- Dryer basics - power cord problems
- Dryer basics - dead dryer
- Dryer *general* repair flow chart....Click here
- Gas dryer smell
- How do dryer thermostats work?
- How long can my dryer vent be in length?
- How to change a common rear drum seal
- How the belt is suppose to look at the motor and idler pulley
- Help on replacing dryer motor and some wiring tips for the 279827 motor
- Help on replacing dryer motor and some wiring tips for the 279787 motor
- Help for storing an appliance
- Important Disclaimer
- I dropped something down the lint filter area....help!
- Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
- Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
- Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
- Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
- Inglis, Whirlpool and Kenmore electric element changing procedures
- Inglis, Whirlpool and Kenmore dryers - air flow
- Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
- Inglis, Whirlpool and Kenmore style dryers - belt change
- Inglis, Whirlpool and Kenmore dryer general motor problems
- Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
- Inglis, Whirlpool and Kenmore dryers - where are my thermostats
- If your drum belt looks like either of these....change it!!
- Idler pulley slide troubles with newer Whirlpool build Roper dryer
- My dryer will not shut off
- Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
- Pilot flame help
- Sample wiring diagrams
- Test for ohm meter checking on electric dryers with no heat
- Taking apart an Duet or HE3 dryer for a belt change
- Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
- Timers and some common Auto dry troubles and solutions
- What is a grounded element?
- Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + Expanded repair helps for a common "Even Heat" dryer
7/28/2012 11:08:57 PM •
Whirlpool...
Answered
on Jul 28, 2012
Lent and dryer debris building
Yes the baffles could be removed to clean them by removing the lint filter,in the top where the filter goes are 2 phillips head screws,remove them,use medium sized straight blade screwdriver and place it in the seam between the top in and front panel and pop up the top,them pivot back against the wall(dont worry it is hinged in the rear and wont fall off). You will see the drum and can remove the screws that screws that hold the baffles in place,to rotate the drum to get to each baffle rotate it by hand in a counterclockwise direction.
Gene
8/7/2011 1:02:01 AM •
Whirlpool...
Answered
on Aug 07, 2011
Dryer does not heat
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
6/19/2011 8:01:10 PM •
Whirlpool...
Answered
on Jun 19, 2011
The dryer is not heating up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
11/15/2010 3:03:34 PM •
Whirlpool...
Answered
on Nov 15, 2010
Whirlpool gas dryer we have the ignitor comes on,
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
heatman101
9/12/2010 10:01:13 PM •
Whirlpool...
Answered
on Sep 12, 2010
We are in a new house and trying to figure out how
As short as possible with no turns if possible. Ideally it would be short and stright, If possible have someone small that can climb over machine after tighting the clamps. Use a aluminum hose and snips or dikes to cut. Do not use the plastic ones they are a fire hazard and a code violation in many states.
7/11/2010 11:27:03 PM •
Whirlpool...
Answered
on Jul 11, 2010
I have a dryer that runs but no heat. I removed
the fuses are usually found at an appliance parts store. You can google "whirlpool dryer parts" and find a parts store near you or one you can order from over the internet. I have replaced many of those, and they cost between 20.00 and 30.00 dollars.
6/18/2010 8:37:13 PM •
Whirlpool...
Answered
on Jun 18, 2010
Not heating
If it has been moved recently or just jostled around the small heater element that prompts the gas valve to open up may have broken, open the front cover and check out the element, it should make a complete circuit from and back to the wire connector.
I’m happy to assist further over the phone at
https://www.6ya.com/expert/gregg_78ecbb34e27be215
6/14/2010 3:10:58 PM •
Whirlpool...
Answered
on Jun 14, 2010
Heating fuse
There is a thermal fuse and a thermal cut off that can stop the heat entirely.
If you have some heat but not enough these are not the issue, let me know and I can go deeper if needed.
The thermal fuse is located behind the back panel just to the left of the exhaust outlet. It is white with 2 blue wires going to it.
The thermal cut off is behind the back panel on the right side about 1/2 way up the metal box. It also has 2 wires going to it (usually red).
4/24/2010 2:49:28 PM •
Whirlpool...
Answered
on Apr 24, 2010
