20 Most Recent Gateway M280E Questions & Answers
0answers
manual
M280E Manual
Gateway M280EUploaded on Feb 23, 2015
2answers
I cant find the start button on the desktop
Desk top computers have an ON Button on the front panel or at the very top margin. OR is it a LapTop?
2/16/2015 7:27:57 PM • Gateway M280E • Answered on Feb 16, 2015
Keep cursor moving and and drive
if the cursor is moving by it self you do have a virus. When you restart the computer bring it up in safe mode and check for a virus using maleware byte from Cnet.com
10/22/2014 5:59:19 PM • Gateway M280E • Answered on Oct 22, 2014
Hard drive and cursor freeze
it sound like you might have either a virus or you don't have enough ram to run a the program you want. Go to Cnet.com and download malware byte and check for a virus in safe mode
10/22/2014 5:51:38 PM • Gateway M280E • Answered on Oct 22, 2014
Upgrade hard drive
b9863391-bc66-4456-9d11-5f1787312d10.jpgprovided you format your new drive first you can put most any in. To format buy a wire kit that you can plug the drive into a usb the kit comes with a power supply transformer.http://www.ebay.com/bhp/sata-to-usb-adapter
11/7/2013 2:49:13 PM • Gateway M280E • Answered on Nov 07, 2013
I own a gateway M280
if your installing windows 7 it will have all the touch screen drivers and such already built in, just a matter of enabling then in your control panel
12/13/2012 6:08:27 AM • Gateway M280E • Answered on Dec 13, 2012
2answers
Have a gateway M280 laptop that I need to replace
First off you would need to have a compatible motherboard for your machine (you can order this from the manufacturer of your computer). Before getting one you would need to consider what type of Memory do you have if it will be compatible for the new motherboard, the type of hard drive your computer uses. The video card and the USB ports if they will still be in the same location. Then you will need a set of precision screws to remove the small screws holding the back cover of the computer.
After removing the screws, check the sides for hinges you can pluck to completely remove the back cover. You would have to detach the keyboard and the LCD panel as well before you open the back of the laptop.
Once done put the replacement board in and one by one attach the old components to the new motherboard the secure the covers and the screws.
This may be easier said than done so please proceed with extreme caution as laptop components are more sensitive than their desktop counterpart.
If you would replace the motherboard of your computer I would suggest you think about it because a replacement board would cost you around $175 - $200 now if you'd just add about a $100 more it could get you a new computer from DELL or HP.
Hope this helps!
8/31/2011 4:57:21 PM • Gateway M280E • Answered on Aug 31, 2011
My wife was using her
Try to replace the power button? Helped me on one laptop.
5/3/2011 3:28:19 AM • Gateway M280E • Answered on May 03, 2011
Gateway TabletM280e screen broken. What is needed
Assuming the screen is physically cracked, you need to obtain a new screen, remove the screen bezel by popping off the rubber caps and undoing the screws under them. The screen is fixed into position by two rails with small screws holding it into place. Remove these and the screen will be freed.
Disconnect the VGA cable and the smaller two wire plug that connects the inverter to the screen, replace the new screen and re assemble
3/27/2011 10:38:42 PM • Gateway M280E • Answered on Mar 27, 2011
Will not power on new power supply and battery
first thing is to check fuse in plug of P.S.U
3/3/2011 9:08:54 PM • Gateway M280E • Answered on Mar 03, 2011
How do I install a keyboard in a Gateway M280E
Power off and remove battery. Remove 2 screws on back cover marked with a K. Open display, gently pry off long thin silver panel between display and keyboard. With fingers at top of keyboard, pull up and flip top over toward ypu, then lay flat and upside down. Disconnect flat cable and remove the keyboard. Reverse steps to replace.
12/28/2010 3:14:17 AM • Gateway M280E • Answered on Dec 28, 2010
M280E (41891001) Tablet PC: the screen is very dark, cannot adjust brightness...
hp tablet compaq tc4200: the screen is very dark. cannot adjust in control panel, it's greyed out,
11/12/2010 11:34:19 PM • Gateway M280E • Answered on Nov 12, 2010
Broken swivel hinge on Gateway m280e laptop.
not sure about documentation - but for parts you might try dakotapcwarehouse.com - my company has found parts for a lot of its older gateway laptops there
9/8/2010 2:39:48 PM • Gateway M280E • Answered on Sep 08, 2010
3answers
Fan continues to run
I don't think a Mercedes coolant problem will fix your laptop. The fan on most laptops runs all of the time. Many are sensor driven and the fan speed will increase with processor activity. If your fan seems to be running okay, and is not making too much noise, you may just need to take the unit apart and clean out the dust bunnies. They will greatly affect the heating properties. If you need a service manual for disassembly, it is available at mpcdrivers.com
4/10/2010 5:27:24 PM • Gateway M280E • Answered on Apr 10, 2010
Hi i like to install xp profecianal on my laptop
XP professional will not work on that unit. The OS will install and work properly but you will lose many of your tablet functions. You have to have the tablet pc edition for all comonents to function. You would not gain anything by going to Pro, and your Windows or Microsoft update will keep your current tablet pc edition updated properly.
4/10/2010 5:22:03 PM • Gateway M280E • Answered on Apr 10, 2010
2answers
How do i separate the case covers on a gateway
there are numerous screws on the bottom and top some under cover and the keypad, to remove keypad thereare screws under the harddrive i think, but you must remove the memkory and wireless cards as well as the cd drive and you must remove the screen carefully and the wiring for that the keyboard flat wire has a black clip you should lift to release the wire. complcated job just take you time.
4/10/2010 5:19:48 PM • Gateway M280E • Answered on Apr 10, 2010
Gateway M280E Logo
49 questions posted
Top Gateway Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Tablets & eReaders
Most Popular Question
upgrade hard drive
  • Tablets & eReaders
