20 Most Recent Whirlpool LER2614JQ Electric Dryer Questions & Answers
Dryer won't start
it may have a belt switch. hope this helps.
2/11/2018 6:19:52 AM • Whirlpool... • Answered on Feb 11, 2018
Does not dry,no heat at
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
8/13/2010 3:23:22 AM • Whirlpool... • Answered on Aug 13, 2010
My Dryer won't heat up
You will need an ohmmeter to check the element and the hi limit thermostat and the non resetable thermal fuse. These are all axcessed through the rear panel if the dryer.
3/27/2009 3:07:46 AM • Whirlpool... • Answered on Mar 27, 2009
Fuse
This electric dryer has a thermal fuse. If blown, the drum will not turn. On a gas dryer the drum will still turn but no heat. The thermal fuse is located on the blower housing. You have to remove the back panel to get at it. It will be the white fuse located right above the fixed thermostat. Two wires going to it. Catriver.
4/26/2008 10:37:58 PM • Whirlpool... • Answered on Apr 26, 2008
Dryet
Shelly on some of the older models they used a inline resistor on the dryers timer. It looks like a inline fuse comming off the timer. If it goes bad the timer will not stop. Check the attachment. Cost around 17.00, Catriver, post back. Part number 3401076
4/2/2008 3:14:06 PM • Whirlpool... • Answered on Apr 02, 2008
Whirlpool LER2614 repair
The problem was that the dryer did not work when the start button was pushed.
The cause was the paddle that controls the door switch. I fixed it but thanks to those who gave suggestions.
3/31/2008 8:55:53 PM • Whirlpool... • Answered on Mar 31, 2008
Drum won't turn
if your lint screen is on top of dryer pull it out and remove the 2 screws under it. then there are 2 clips under the front edge of the top. with a putty knife you can press the clips to raise the top. after top is up look inside on the right and left top part of the front of the dryer there is a screw on each side should 1/4" or 5/16" head. remove thoughs screws and front folds forward and lifts up to be removed.
11/25/2007 6:42:18 PM • Whirlpool... • Answered on Nov 25, 2007
Problem with my dryer
unlikely a fault with dryer. try plugging another high consumption item into the socket you use for the dryer ie elec kettle or iron. see if breaker still trips and if so you have fault in socket or house wiring. if you put a plug on the dryer yourself, check you have wired plug correctly
10/7/2007 4:34:49 PM • Whirlpool... • Answered on Oct 07, 2007
Whirlpool WGD4800XQ1 Dryer-- Replaced burner coils and it worked great. The next day no ignition again.
There are about seven different possiblities and the prospective solution in each case appears to be replacement of a different part! I suppose if you have the proper testing equipment for assessing each of those parts, you might be favored with a relatively inexpensive fix. I would be embarassed to suggest you replace all in sequence until the dryer works. Thermal Fuse: The thermal fuse is a safety mechanism that prevents the dryer from overheating. If it blows, the dryer won't heat. Check if the thermal fuse is intact and replace it if necessary. Cycling Thermostat: The cycling thermostat regulates the temperature inside the dryer drum. If it's faulty, the dryer may not heat properly. Consider checking and replacing the cycling thermostat. Igniter: The igniter is responsible for lighting the gas burner. If it's defective, the dryer won't ignite. Inspect the igniter for any signs of damage or malfunction. Gas Valve Coils: Although you've already replaced them, double-check the gas valve coils. Sometimes, even new parts can fail. Ensure they are securely connected and functioning correctly. Ventilation: Poor ventilation can lead to longer drying times and affect ignition. Make sure the dryer vent is clean and not obstructed. A clogged vent can cause overheating and affect ignition. Door Switch: The door switch ensures the dryer doesn't operate when the door is open. If it's faulty, the dryer won't start or heat. Verify that the door switch is functioning properly. Timer and Controls: Check if the timer advances correctly during the drying cycle. Malfunctioning controls can impact ignition. Inspect the timer and control board for any issues. Whirlpool Dryer WGD4800XQ1 - OEM Parts & Repair Help - PartSelect.com
4/4/2024 12:10:04 AM • Whirlpool Dryers • Answered on Apr 04, 2024
On a cabrio whirlpool dryer what does E4 and F4 codes mean
A "F4E4" (Low or No Line Voltage) code indicates there may be a problem with your home power supply, keeping the dryer's heater from turning on. The dryer will continue to run when this diagnostic code is present. Touch any pad to clear the code from the display and return to the estimated time remaining.
1/20/2024 7:55:51 AM • Whirlpool Dryers • Answered on Jan 20, 2024
How do I remove and replace an Amana Whirlpool clothes dryer start switch?
Push to start relay switch. NOTE: If the dryer will not start check the thermal fuse before ordering start switch. The switch is often not the cause of the dryer failing to start. pull the knob off the switch the answer should be visible
1/9/2024 4:54:28 PM • Whirlpool Dryers • Answered on Jan 09, 2024
Whirlpool Duet Dryer Won't Start
possible bad motor
11/5/2023 4:38:01 AM • Whirlpool Dryers • Answered on Nov 05, 2023
Whirlpool ED9270XW1 dryer when you hit the start button, the dryer will not start?
Never 'hit' the Start Button, always press it gently. It is part of the main control board. Whirlpool dryers can be reset by disconnecting the power from the wall socket overnight. Apart from that, you would need to disassemble it and check the Thermal Cut Out, the Thermal Fuse and the Thermostat with a digital multimeter.
Is There a Reset Button for Whirlpool Dryers?
Hunker https://www.hunker.com > ... > Washer & Dryers This is done by pressing "Start" for a few seconds to restart the dryer. If the dryer does not restart automatically, select a new cycle and any options then ... ..
10/21/2023 8:31:28 PM • Whirlpool Dryers • Answered on Oct 21, 2023
Whirlpool WED7500GW0 dryer. How do I remove a whirlpool dryer back panel please?
Question edited for clarity. You normally get inside them from the top and front. What are you trying to do? That is the important part! This gives generic advice https://www.google.com/search?q=whirlpool+dryer+wed7500gwo+belt+replacement ..
9/22/2023 2:31:32 AM • Whirlpool Dryers • Answered on Sep 22, 2023
E1 Error on Whirlpool Duet Dryer GEW9250PL1
wow, that is a tale of woe. Well E1 is definitely the thermistor, but you can check it with a multimeter. It may be a bad batch, or it could be the wiring. You should never replace components on guesses, fuses and elements are an easy test. The remanufactured board may also be at fault. The unscrupulous take them off machines, clean them and sell them on untested. https://www.google.com/search?q=E1+Error+on+Whirlpool+Duet+Dryer ..
9/1/2023 3:45:56 PM • Whirlpool Dryers • Answered on Sep 01, 2023
Whirlpool gas dryer GGW9250PW0. In diagnostics I get 88; open door and get 69. My problem is that the dryer doesn't start at any setting and stays on sensing. Thermal fuse and thermistor are good
It is a GAS dryer, that means you can't work on it yourself. Only registered qualified gas technicians can work on gas appliances and that is the law. Plus, if it is the main control board, you want professional diagnostics due to the cost of them.
8/6/2023 12:26:21 AM • Whirlpool Dryers • Answered on Aug 06, 2023
Whirlpool duet model YWED9300VU0
Try kit 4392067. It's the 4 roller wheel kit with belt and pulley. I use them all the time on that model, but without the Y in the beginning. Not sure what the variation is there.
8/3/2023 3:40:43 PM • Whirlpool Dryers • Answered on Aug 03, 2023
How do I remove the top of a Whirlpool Cabrio dryer WED5600XW0 to replace the door switch? The lint trap is under the door. I don't see the clips.
Aha, a new question Meri. Not 'lifting the LID', 'removing the TOP' of the Dryer. The videos show the job.
7/21/2023 2:17:47 AM • Whirlpool Dryers • Answered on Jul 21, 2023
Whirlpool LER2614JQ Electric Dryer Logo
8 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
fuse
  • Dryers
