20 Most Recent Amana ACD106R Wall/Window Air Conditioner Questions & Answers
2answers
Getting an E1 error message..wont
1. Unplug unit. 2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off. 3. Release power button and unplug. 4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
9/5/2012 9:41:13 PM • Amana ACD106R... • Answered on Sep 05, 2012
0answers
E1 code
Be the first to answer 8/4/2012 4:02:01 PM • Amana ACD106R... • Posted on Aug 04, 2012Be the first to answer
0answers
Compressor will not shut when
Hello, Here is a trouble shooting guide for you and some details of how to fix it based on your symptoms. Here is a link to go to and make sure you jump around the site, it will tell you the fix based on your problem off the trouble shooting table. Link is below , copy and paste in browser. If this helped you, please rate it and some kind words are nice. Thanks Mike http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
10/20/2011 4:03:57 AM • Amana ACD106R... • Answered on Oct 20, 2011
When I turn my window
Needs cleaning.Hello, Here is a trouble shooting guide for you and some details of how to fix it based on your symptoms. Here is a link to go to and make sure you jump around the site, it will tell you the fix based on your problem off the trouble shooting table. Link is below , copy and paste in browser. If this helped you, please rate it and some kind words are nice. Thanks Mike http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
10/20/2011 4:03:09 AM • Amana ACD106R... • Answered on Oct 20, 2011
I have a E1 where the temp is and the air
10/20/2011 4:02:19 AM • Amana ACD106R... • Answered on Oct 20, 2011
2answers
Called customer service for E1
Good day!!!!
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If it doesn't work you need to buy a new unit instead you repair it for $250...If that is the repair cost its better to buy a new machine...
I hope it helps
Thanks for using fixya..
8/28/2011 8:37:23 PM • Amana ACD106R... • Answered on Aug 28, 2011
0answers
Cooling mode (low and High)
I would have someone take it out of the window (if it isn't already) and with a water hose - wash both coils, (if you use a pressure nozzle be careful to not bend the fins on the coils). The coil at the back of the unit is called the condenser coil, and the one in the front is the evaporator coil, (do not get water in the fan motor or where the switches and wires are located - wrap with plastic/tape or something to keep water out). Try to keep from tilting unit on it's side or upside down, but if you have to (and you might in order to drain water from unit), just do so for a short period. Don't leave the unit on it's side or upside down while it dries out. Let it dry really good and do not try to start unit for several hours especially if you had to tilt it on it's side/upside down.
Once you've washed both coils really good and the unit has dried out - you can buy 'washable filter material' (Home Depot/Lowe's) that you can 'cut to size' and install on the front (evaporator) coil. The filter goes 'in front' of the evaporator coil (sometimes it slides into the inside of the plastic front cover - but in any event the front cover helps to keep the filter in front of the coil) - the idea is for the filter to catch dirt/hair and whatever - before it gets in the front (evaporator) coil and clogs it up. (NOTE: the reason you must have a filter in front of this coil is that the fan motor is drawing air from inside the cooling space, and through the coil.
You should always keep the filter clean which will keep your front (evaporator) coil clean. If it get's clogged with dirt, hair and etc - it will affect the operation of the AC in a very negative way.
As for the back (condenser) coil - it will usually stay fairly clean although you need to keep a eye on it and keep it clean - but, in general it does not need the careful attention that the front coil requires, and "does not" require a filter.
I would then look and see if there is a place (probably not) to oil the bearings on the fan motor. If you do have oil spouts on the bearings (of the motor) be sure and put a few drops of oil in each of them. As I said though, most motors are 'oil-less' these days - even 10 year old units.
After doing all this - you've done about as much as you can do - and you can either put it in the window and hope it works ok (which it might) - or you can have a serviceperson check it out for proper operation. If you look in the newspaper/craig's list - you might get lucky and find a 'retiree' who works on window units and if you take it to him/her you could probably get it checked out for a reasonable charge.
It is doubtful that you have a 'refrigerant problem,' since you said it cooled part of the time, and as for the 'cooling mode working intermittently or not at all ' I'm thinking it might work ok - once the coils have been cleaned. Something else to consider is that the 'speeds of the fan motor' are so close together - it might be hard to tell 'low' from 'high' speed when in the cooling mode.
I don't know how much trouble it would be to put back in the window and try for proper operation and then take out (if it didn't work right) but I think I would try it. Or, you could just try it in the garage or someplace before putting in the window. In any event - from what you've said - I think it's worth a shot to clean it up and possibly have a serviceperson look at it - especially when you consider the cost of a brand new one. The 'important thing' you said was that it 'cooled' at least part of the time, which tells me the compressor (the most expensive part of the AC) is working ok.
Hope this has helped.
6/12/2011 9:46:17 PM • Amana ACD106R... • Answered on Jun 12, 2011
0answers
I have a amana window unit 12,000 btu with the
Indoor fan motor mechanism locked or short circuited. Replace it.
1/1/2011 5:13:28 PM • Amana ACD106R... • Answered on Jan 01, 2011
Its showing e1
Error code E-1 Refers to the problem of clogged air Filters.The filters are clogged with dirt .Clean the air filters and check. If cleaning the filters does not help then try turning the unit off and unplugging it from main power outlet .If that doesn't reset it then you probably have a PC board or temperature sensor failure.It has to be checked with meter to confirm the faulty part.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
6/6/2010 7:02:17 PM • Amana ACD106R... • Answered on Jun 06, 2010
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
8/6/2009 5:13:00 AM • Amana ACD106R... • Answered on Aug 06, 2009
Beeping Noise
when the air conditioning aircon is have niose get a more prion in the copper tube and you will see the effect
6/22/2007 8:11:34 PM • Amana ACD106R... • Answered on Jun 22, 2007
What if I replace 1/3 blower motor with 1/2 motor on Amana 80 SSE Furnace?
The important consideration is the rotational speed and adding extra horsepower really doesn't achieve anything because the motor isn't really under 'load' as it would be in say a winch. It is better to stick to OEM Specs https://www.google.com/search?q=amana+80+sse+blower+motor ..
2/6/2024 5:18:53 AM • Amana Heating &... • Answered on Feb 06, 2024
Amana DigiSmart PTH153B50AM 14000 BTU Heat Pump. What Amana model replaces PTH153B50AM please?
Question edited for a lot more clarity. The new improved energy efficient versions.
The Improved Amana R-410A PTAC Unit Uses Less Energy
Amana PTAC https://www.amana-ptac.com > products > ptac Looking to buy an energy-efficient PTAC unit for your building? Buy the new Amana R-410A PTAC unit heat pump, which reduces energy consumption by 35%. Probably this one. Talk to your installer. https://www.amana-ptac.com/products/ptac/hec154j ..
1/10/2024 5:01:34 AM • Amana Heating &... • Answered on Jan 10, 2024
Amana PTAC air conditioner. Switch to a wall thermostat?
Question edited for clarity and toss in some CAPS. You can get wired or wireless. https://www.amana-ptac.com/products/ptac Fitting https://www.google.com/search?q=amana+ptac+connect+to+wall+thermostat .
7/26/2023 3:29:14 PM • Amana Heating &... • Answered on Jul 26, 2023
Amana ACD106R Wall/Window Air Conditioner Logo
23 questions posted
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
when turn window
  • Heating & Cooling
