20 Most Recent Whirlpool GEW9250 Electric Dryer Questions & Answers
that knob is actually a switch. fixing it will be much easier, if you replace the whole switch unit..
good luck..
Whirlpool... | Answered on Mar 11, 2019
you may have a bad motor control board they are very expensive. There are screws on rear top panel and the top slides off. The board is located on the left side. If you hear a click when you start it then there is a relay got on board.
Whirlpool... | Answered on Mar 24, 2018
if you checked all the t-stats and they checked good the only two things left is the board and the motor,it takes 240 volts to get heat 120 comes from the board and the other 120 volts comes from the motor,first go to the block where the cord connects to the dryer and make sure you have 240 volts there,but you say you changed the thermister and you had heat?check both thermisters to see if you get the same reading on them both should be around 10k ohms,that could of been coincidental With the resistance value at room temp on the thermistor being good then this would not be a thermistor error. There are 2 components other than the thermostats which would cause the heating element not to work. First is the motor and second the Control board. The best option is to disconnect the power to the unit and access the heating element. Disconnect one wire that is going to the heating element, preferably the one on the thermostat side. Plug the unit back up and using a multimeter you will want to turn the dryer on and test for 120 vac at the terminal on the heater where the wire was disconnected. What this will do is eliminate the heater element itself and the motor. If there is 120 vac at this point then you know the heater is good and the motor is good because the other 120 vac coming through the thermostats is the control board side of the circuit. If there is not 120 vac at that point then you will want to test the other terminal on the heater and check for 120 vac. If there is not 120 vac then the motor would be bad .
Whirlpool... | Answered on Feb 03, 2018
not make for large blanket change the white fuse air not going out
Whirlpool... | Answered on Nov 15, 2017
In many machines, those elements, which are manufactured by "robots", are very cheaply made.
Rather than risk a fire, perhaps an investment of 20 - 30 dollars for a new element might be a good idea.
If you decide to do this, take a second look around for what specifically is getting so hot it is melting.
Likely the loose wire inside the element is doing that problem.
I should guess it is out of it's place and is melting an adjacent wire outside the heating element.
God bless your efforts.
Whirlpool... | Answered on Oct 07, 2017
next to the motor could be a silver capacitor..................may be duff........with the lid off............ powered on..........push the top of the drum...........if it starts going........its the capacitor................be careful..........
cheers
Whirlpool... | Answered on Jul 29, 2017
Yes it is either the belt or the guide wheel which will smell like rubber if it is bad
Whirlpool... | Answered on Jul 19, 2017
You must have a bad thermistor. The program aint getting any signal from it and dont know the temp inside the dryer.
When you call for drying the control checks with the thermistor mounted on the blower housing inside the machine. The reading informs the control the ambient air temp. The dryer kicks in and does another check after a moment to see if everythang is kosher. If it determines dampness then it continues onward till the desired resistance reading indicating the clothes is all dry and she goes into cooldown no heat to allow the clothes to keep from wrinkling. You either have a bad thermistor a bad control or a bad connection between the 2. Look for Dan Webster youtube appliancejunk repair manuals and find your free manual i have in there. Thanks good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Whirlpool... | Answered on Jun 30, 2017
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Whirlpool... | Answered on Jun 17, 2017
sounds like the door switch
Whirlpool... | Answered on Jun 12, 2016
There are screws on the back of the top panel. When you remove the top panel, there screws become visible that hold the front panel on.
Whirlpool... | Answered on Apr 23, 2016
Clean the lint trap and make sure you have good fan operation. Check your outside vent for good air flow. Could your burning smell be electrical wiring? Does it smell like plastic burning or lint burning?
These are things one needs to know in order to locate the trouble.
Whirlpool... | Answered on Feb 10, 2016
Any service codes showing (E1,E2...)? Does the drum turn if you hold the start button in? If so, do not continue hold. There are a couple of safety switches that will keep the dryer from running if they fail. One is the dryer door switch and the other is the belt tensioner switch. If the door switch fails, it will appear as though the door is open, thus will not stay running. If the belt switch fails, the dryer thinks the belt is broken, resulting in a no run condition. If you are handy with a volt/ohm meter, these can be checked. Make sure it is unplugged before removing any panels.
Whirlpool... | Answered on Jan 17, 2016
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Whirlpool... | Answered on Aug 13, 2015
bottom button on last row on right side of control panel depress and hold for 3 seconds it should activate or deactivate control lock if this does not help you could have a faulty control panel
Whirlpool... | Answered on Jul 19, 2015
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
Whirlpool... | Answered on Jul 08, 2015
Whirlpool GEW9250 Electric Dryer Logo
1,106 questions posted
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
gew9250 electric dryer runs but no heat
  • Dryers
