20 Most Recent Husqvarna Rz5424 Zero Turn Lawn Mower Kohler Courage Engine Questions & Answers
I have a 2014 HUSQVARNA RZ5424 that I just changed the blades on for the first time now 2017. I got new gator blades because of all the good reviews on them. They are about as good as a screen door on a submarine at 300 feet deep. There the same length as the original blades but leaves two rows of uncut grass about a inch wide regardless of how you try to cut it. Only 240 hours on mower, deck clean ,spindles kept greased . Went back to new Husquvarna blades like the ones made for it. PROBLEM SOLVED. HAPPY HAPPY HAPPY. REL.
Husqvarna Rz5424... | Answered on Jul 16, 2017
Follow the shaft/arm that the brake pedal is attached to, the switch will be activated by that pedal arm.
Husqvarna Rz5424... | Answered on Oct 31, 2016
are you sure its the starter and not the solenoid? or a loose ground?
Husqvarna Rz5424... | Answered on Sep 02, 2016
Have you checked for stones, twigs, dead squirrels, etc. In the drive gear and wheels?
Husqvarna Rz5424... | Answered on Jul 13, 2016
if the is no tail sticking out then NO you can not fix . just replace with a new one .
Husqvarna Rz5424... | Answered on Jun 27, 2016
In my younger day if you did not idle down and cool off before shutting off the switch it would backfire and break the connecting rod. Carbon builds up on the head and glows red from heat, when you got up the safety switch for the seat shut it off . The red hot carbon on the head lit the fuel with the piston in who knows what position. If you can remove the spark plug and put your thumb over the spark plug hole and crank it over, should be compression and blow some air around your thumb. You might of got luck and blowed out the head gasket, check that out and come back.
Husqvarna Rz5424... | Answered on Apr 02, 2016
Goggle it. owner's manual for ------------
Husqvarna Rz5424... | Answered on Nov 15, 2015
Yes, the solenoid gear teeth are jammed. For a temporary fix, you may try tapping on it with a hammer on the side of the cylinder to unjam it temporarily. Replace the solenoid. It's easier to install it and have the entire starter checked by a starter rebuild shop to assure our good guess solves your problem.
Husqvarna Rz5424... | Answered on Apr 09, 2015
my transmission on the right side do not have the power the lifr side have what do i need to do to fix it
Husqvarna Rz5424... | Answered on Mar 14, 2015
ether unplug it if wont start then jump the wire pigtail with a wire you can bypass both switch like this
Husqvarna Rz5424... | Answered on Sep 16, 2014
Where is the grinding sound coming from??? Could be your hydrostatic transmission. When one side goes the other will follow... Time for a new mower... Mine lasted 3 years...
Husqvarna Rz5424... | Answered on Aug 06, 2014
Husqvarna Rz5424 Zero Turn Lawn Mower Kohler Courage Engine Logo
34 questions posted
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
replaced battery now starter engages
  • Garden
