20 Most Recent Husqvarna New Zero Turn Lawn Mower RZ4623 Questions & Answers
Husqvarna New Zero Turn Lawn Mower RZ4623 will not go into gear
Not sure the problem, there are no gears on the drive system. This uses Hydro drive wheel units. If the belt is on and in good shape, check the lever linkage.
12/12/2017 7:07:01 PM • Husqvarna New... • Answered on Dec 12, 2017
How to fix brake release RZ4623
If you a push button. A new switch
7/12/2014 11:20:37 PM • Husqvarna New... • Answered on Jul 12, 2014
Where is alternator on a rz4623
Under the flywheel
5/30/2014 1:27:50 AM • Husqvarna New... • Answered on May 30, 2014
2answers
How do I find out what year my Husqvarna yth18542 42 in riding lawn mower was made in
yth18542 is the model number of the lawn tractor, the identification plate should also show a serial number, which can be used to identify the date of manufacture as well as to differentiate between differences in this model, depending on date of manufacture. https://www.husqvarna.com/us/products/riding-lawn-mowers/yth18542/960430172/
4/16/2024 6:17:40 AM • Husqvarna Garden • Answered on Apr 16, 2024
2answers
Governor on briggs 445677
Looks like your governor crank broke. Go to www.parttree.com
4/12/2024 1:16:56 AM • Husqvarna Garden • Answered on Apr 12, 2024
What kind of blade can i put on my Husqvarna 322L weedeater to cut little trees up to size 1/2 to 1?
copy and paste into search engine Husqvarna Blade Conversion 537048502 537 04 85-02 322L 323L 324LX 325LX 326L
3/21/2024 4:41:48 PM • Husqvarna Garden • Answered on Mar 21, 2024
2answers
I have a Husqvarna HU700F. I need a new grass bag. I can only find one for an HU700. Would that fit?
Here is the bag, use your existing frame https://saffordequipment.com/product/husqvarna-black-grass-bag-oem-580947302/ Husqvarna Black Grass Bag OEM #580947302 **Bag Only, Does not come with Frame** Compatibility This part is compatible with the following machines: Husqvarna HU700F (2012-11)(96145000900) Walk Behind Mower Also available at Walmart and Sears https://www.google.com/search?q=husqvarna+hu700f+grass+bag
OEM Husqvarna 580947307 Fabric Grass Bag ONLY For ...
Walmart https://www.walmart.com > OEM-Husqvarna-580947... Husqvarna. OEM Husqvarna 580947307 Fabric Grass Bag ONLY For HU550F HU550FH HU700F HU800H. USD Now $55.00. You save $14.58. You save$14.58. was $69.58$69.58. US$55.00 ..
1/28/2024 8:02:53 PM • Husqvarna Garden • Answered on Jan 28, 2024
Husqvarna YTA24V48 Lawn Tractor. Need drive belt diagram for it please?
Question edited for clarity. Shown on Page 20 of the manual. https://www.manualowl.com/m/Husqvarna/YTA24V48/Manual/493664?page=20 ..
11/29/2023 9:34:18 PM • Husqvarna Garden • Answered on Nov 29, 2023
Husqvarna zero turn 560 lawn mower how do I raise the seat
See attached. .. manual available at
https://www.husqvarna.com/us/support/z560x/
11/25/2023 1:15:01 PM • Husqvarna Garden • Answered on Nov 25, 2023
How do I pour gas into my carborator when I run out of gas
why, just fill tank
10/28/2023 8:18:43 PM • Husqvarna Garden • Answered on Oct 28, 2023
3answers
Husqvarna zero turn mower. Starts ok, but when I bring in the right handle the engine dies. The left is ok, I can move it in and go forward slightly with it, but when I engage the right handle the engine shuts off.
Your seat safety switch is not working. If the seat switch isn't activated, ie. a person sitting on the seat, the safety system will stop the engine when the levers are engaged. There is probably only one lever safety switch, on the right lever, which is why the left one doesn't kill the engine. Check the seat switch continuity and the wiring for loose connections.
10/7/2023 2:37:40 AM • Husqvarna Garden • Answered on Oct 07, 2023
2answers
Husqvarna RZ46i 46-in 23-HP V-twin Gas Zero-turn Riding Lawn Mower. It starts then engine revs up, no control.
Question edited for a lot more clarity! The throttle return spring has broken or come unattached. more here https://www.google.com/search?q=Husqvarna+RZ46i+runs+full+throttle ..
10/4/2023 12:05:24 PM • Husqvarna Garden • Answered on Oct 04, 2023
Slow forward drive on hydrostatic mower husqvarva 316 tsx awd
Likely there is air trapped in the system. Try raising drive wheels (safely) off the ground and operating forwards backwards. With minimal load on the hydo pump and motor, the air should purge.
9/22/2023 1:39:14 PM • Husqvarna Garden • Answered on Sep 22, 2023
2answers
Husqvarna 128CD weed eater. The flywheel is tight, piston is at bottom when flywheel magnet is in contact with coil. How can I change it to correct position.
The flywheel key has likely sheared. Contemporary utility 2-cycle flywheel keys are integrated into the flywheel. A new flywheel will be likely be required.
9/7/2023 10:16:53 AM • Husqvarna Garden • Answered on Sep 07, 2023
Husqvarna 128CD weed eater. When flywheel magnet is in contact with coil, should piston be at top of cylinder or bottom.
Question edited for clarity and typo botton to bottom. It should be at the top of the stroke. It is called TDC or Top Dead Centre and is then the spark ignites the fuel and air to force the rotation onwards in the same rotation as travel.
9/7/2023 1:15:17 AM • Husqvarna Garden • Answered on Sep 07, 2023
Where to get rings for Husqvarna 145bt?
The problem is that the engine is a funny size at 40cc. If it was 50cc, you could get away with motorcycle rings. The normal way to size rings is by measuring the bore with an inside micrometer across left to right and then again front to back. The front to back measurement is often a little more worn. Then you order rings by diameter and thickness, Any local engineering company can do this and supply you with generic rings. There is a different model here with rings at $25 but Jack's Small Engines is $57. My advice is get the OEM ones. You will also need to hone the bore lightly to dull the polish. Oil the new rings with 2 stroke oil when fitting them. https://www.google.com/search?q=husqvarna+145bt+piston+rings+size ..
8/5/2023 1:16:02 AM • Husqvarna Garden • Answered on Aug 05, 2023
Husqvarna 125b keeps flooding and will not start...why?
Weak spark or no spark or spark at wrong time. Do not use a neon type spark tester as it will indicate spark when it is insufficient. Use an inline gap type tester.
To test for spark, compression, and timming, drain all the fuel, choke off and give the the starter several pulls. If the plug is wet, leave plug out and give it several pulls, reinstall plug and give it several pulls, then check plug. Repeat until all residual fuel is gone and plug remains dry.
Now that all fuel is gone you can use an alternative fuel, i.e. starter fluid, that won't flood the engine.
Air filter removed, hold throttle open and spray a 1 second burst directly down the carburetor throat, release throttle. Leave air filter off and promptly attempt to start, several pulls. If no fire then it's likely a spark or compression issue, not the carburetor.
If it fires and runs for a few seconds, then timing, compression, and spark are OK and carburetor remains suspect.
Comment for further assusrance.
7/28/2023 3:49:20 AM • Husqvarna Garden • Answered on Jul 28, 2023
Husqvarna mower YTH 24K48 steering shaft teeth shearing off due to hitting pulley
Check the deck ant--sway bar is in the correct location. See attach.
Owners manual available no fee download at
7/17/2023 4:43:47 PM • Husqvarna Garden • Answered on Jul 17, 2023
Husqvarna New Zero Turn Lawn Mower RZ4623 Logo
Popular Tags
6 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
husqvarna new zero turn lawn mower
  • Garden
