20 Most Recent
Simplicity Legacy XL 27hp - Kawasaki Liquid Cooled Questions & Answers
Why can't I raise my plow
usually this would be a electrical issue or a stuck control valve but you didn't mention the plow manufacture or give the model number
HELP
seat switch may be bad.
My 4040 Simplicity tractor will not go. Wife was
Can you turn the shaft pulley by hand with the engine not running? If so your key is still there but broken off. Check all belts and see if they are ok or maybe has come off the pulley. Check belt tightness as well. Belt also could be worn out so it slips.
Transmisson not working
Check to see if the belt fell off one of the pullys. Also check to see if you have fluid in the tranny. Lastly....check the linkage and spring too.
Simplicity 16hp Briggs stalls
Check the slow running jet for glogging, set the mixture screw 2 turns from fully closed and make sure the small filter connected to the fuel tank is not blocked.
