20 Most Recent Frigidaire GLEH1642FS Front Load Electric Laundry Center. 3.1 cu. ft Washer and 5.7 cu. ft. Dryer Capacity, 16 wash cycles, Stainless Steel Dryer Drum, Energy Star, Stainless Steel Wash Basket, Tumble Care Cleaning System, Sound Silencer Plus, precision Dry Moi Questions & Answers
We have a double stack frigidaire - the washer has a very strong musty smell that won't go away, we use powdered detergent
bro subokan mo ang uling ilagay sa loob at isarado ng 24h.
7/1/2012 1:54:53 PM • Frigidaire... • Answered on Jul 01, 2012
2answers
Re: Frigidaire Dryer FEQ332CES0, Heating Element Connection
If the terminal is 5/16 it needs to be 5/16. The reason is that it passes the correct resistance. The smaller the contact, the more resistance and heat. You may be okay with a 5/16 connector in 250'F and that is probably the best option. However, I would image that any local wholesale electrical wholesaler would carry them. https://www.google.com/search?q=5%2F16+high+temperature+spade+terminal Nedco and CES are my go-to wholesalers https://www.google.com/search?q=electrical+wholesaler+near+me ..
3/5/2024 12:44:54 AM • Frigidaire... • Answered on Mar 05, 2024
Frigidaire Affinity Door Open
Help in the link which also refers to the thermal limiter. It is a gas appliance and should be only serviced by a certified and registered gas technician. https://www.google.com/search?q=Frigidaire+Affinity+Door+Open ..
2/23/2024 8:17:23 PM • Frigidaire... • Answered on Feb 23, 2024
Frigidaire LP/ Propane dryer model GLGQ2152ES3. It dried clothes one day the next day it didn't heat up. Changed the ignitor and still no glow. What is the next step. Thank you
It is a gas appliance so has to be worked on by a gas certified technician. Call for service. That is the law. ..
2/16/2024 4:19:34 AM • Frigidaire... • Answered on Feb 16, 2024
How do I put my Frigidaire Dryer FEQ1442ES0 into diagnostic mode?
To put your Frigidaire Dryer FEQ1442ES0 into diagnostic mode, follow these steps:
  1. Hold down the Select and Cancel buttons at the same time for six seconds. After one buzzer sound, the two keys will be released.
  2. Press and hold the Select and Cancel keys for six seconds right away. The display will indicate "r 2" when the buzzer sounds once.
Once you've put your dryer in diagnostic mode, you may run the diagnostic test to find any problems. You can consult your dryer's operating instructions booklet if you require any more help. I hope this is useful.
1/9/2024 1:13:45 PM • Frigidaire... • Answered on Jan 09, 2024
2answers
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post! If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website. Best regards.
10/11/2023 1:26:50 AM • Frigidaire... • Answered on Oct 11, 2023
2answers
Frigidaire dryer model gler642as3 making a grinding thumping
Thumping and grinding is indication of a worn rear bearing and worn drum slides at the front. They are made of felt and are supposed to be oiled periodically. They are an easy replacement on older machines. https://www.google.com/search?q=Frigidaire+dryer+gler642as3+parts ..
8/28/2023 6:36:04 PM • Frigidaire... • Answered on Aug 28, 2023
Looking for a picture of the wire colors where they go on a Frigidaire electric dryer timer part #131225100
The important part that is missing from this question is the model of the dryer as this part may used on multiple models. The correct Google search query is frigidaire (model) replace timer or frigidaire (model) timer wiring diagram The result will be like this and you can click on the images tab as well. https://www.google.com/search?q=%E2%80%8Bfrigidaire+(model)+timer+wiring+diagram I deleted the Answer that you got previously as it was from an AI Answer Bot https://www.fixya.com/users/rege-oluwaseun I am an advanced human being to provide comprehensive and accurate information based on authoritative non-specific answers ..
8/23/2023 4:33:11 PM • Frigidaire... • Answered on Aug 23, 2023
Frigidaire Electrolux GLER331AS2Is Dryer. Is it possible to replace JUST the heating element and not the whole Dryer Heating Element Assembly?
Question edited for clarity. Question moved from Cars and Trucks. No, not normally, it comes as a unit and this is standard procedure. If it is failing in three years, you have an airflow issue which is causing overheating. https://www.partselect.com/PS418120-Frigidaire-131553900-Heating-Element-Assembly.htm?SourceCode=20&SearchTerm=GLER331AS2&ModelNum=GLER331AS2&ModelID=1107102 Having said that, here are bare coils if you want to try it and the price is a lot more favorable, just make sure voltage and wattage matches.
5300622032 Frigidaire Dryer Heating Element Coil
Reliable Parts https://www.reliableparts.ca > ... > Frigidaire Dryer Parts This is a genuine OEM part that works for some models of Frigidaire, Electrolux, White Westinghouse, and Tappan models. The 5300622032 Frigidaire Dryer Heating ... $56.81 · ‎In stock
Amazon.ca https://www.amazon.ca > frigidaire-dryer-heating-ele... Wadoy Dryer Heating Element Heater coil 5300622034 Compatible with Frigidaire Gibson Kelvinator Ken-more Tappan Westinghouse · 4.24.2 out of 5 stars (37). ..
8/8/2023 2:55:48 PM • Frigidaire... • Answered on Aug 08, 2023
Can a Frigidaire GLER331AS2 be wall mounted upside down?
it is you's to mount upside down, whether or not it works well.
7/22/2023 9:02:10 PM • Frigidaire... • Answered on Jul 22, 2023
I have a Frigidaire Affinity dryer. It is heating but is taking 3 Cycles to dry a small load. .
SOUNDS LIKE FAULTY THERMOSTAT / REGULATOR FOR HEATER ELEMENT, COMMON PROBLEM IN DRYERS
6/24/2023 5:50:57 PM • Frigidaire... • Answered on Jun 24, 2023
Frigidaire dryer model LEQ332DSO Stops after a few minutes
There are several things it could be, but before you start throwing parts at it give these folks a call at their 800# tech line. https://www.repairclinic.com/ProductDetail/641599?symptoms=1
6/18/2023 2:59:42 PM • Frigidaire... • Answered on Jun 18, 2023
Frigidaire AEQ8000FE Electric Dryer randomly displays 50 and start stop lights blink and periodic beeping. Pressing panel clears, but returns a few minutes later.
The Frigidaire AEQ8000FE electric dryer is displaying the 50 and start/stop lights blinking randomly with periodic beeping. Pressing the control panel clears the issue, but it returns after a few minutes. Despite this issue, the dryer is working properly.
4/10/2023 7:43:44 PM • Frigidaire... • Answered on Apr 10, 2023
2answers
Dryer Squeak, Tight Drum, Burning Smell
The loud, constant squeak/squeal from your Frigidaire dryer, combined with a burning smell, indicates a serious problem that needs to be addressed. While replacing the drum bearing kit was a good step, it appears that there may be other issues at play. One possible cause of the squeaking could be a worn or damaged drive belt or idler pulley. If the idler pulley spring came off, it is possible that the belt is not properly tensioned and may be slipping or rubbing against the drum, causing the squeaking noise. Additionally, a slipping belt can generate a burning smell as it heats up from the friction. Another possible cause of the burning smell could be a malfunctioning heating element, which may be overheating the dryer and causing the burning odor. It is recommended that you stop using the dryer immediately and unplug it from the power source. It is not safe to continue using a dryer that is producing a burning smell.
2/26/2023 11:48:17 PM • Frigidaire... • Answered on Feb 26, 2023
2answers
I have a Frigidaire Dryer and the outside of dryer It was hot to the touch and hadn't been used in couple days ?
f the outside of your Frigidaire dryer is hot to the touch and the heating element appears to be glowing red hot when the knob is not in the off position, it is likely that there is a problem with the dryer's heating element. It could be shorted, burnt, or damaged in some other way. It is also possible that there is a problem with the dryer's thermostat, which regulates the temperature inside the dryer. If the thermostat is not functioning properly, it could cause the heating element to stay on for too long and overheat the dryer. It is recommended that you stop using the dryer immediately and unplug it from the power source. It is not safe to continue using a dryer that is overheating or has a malfunctioning heating element. It is best to have a qualified technician inspec
2/14/2023 4:10:42 AM • Frigidaire... • Answered on Feb 14, 2023
I have a Frigidaire Window AC Heater combo the cooling works but the heat does not blow hot?
It sounds like you may be experiencing issues with the heating element on your Frigidaire window AC/Heater combo unit. Here are a few things you can try to troubleshoot the problem:
  1. Check the thermostat: Make sure that the thermostat is set to "Heat" and that the temperature is set to a level high enough to activate the heating element.
  2. Check the air filter: A dirty air filter can restrict airflow and prevent the heating element from functioning properly. Clean or replace the air filter if necessary.
  3. Check the heating element: The heating element may be faulty and needs to be replaced. Consult the manufacturer's manual or contact the manufacturer's customer service for further assistance.
  4. Check the blower motor: The blower motor may be malfunctioning and needs to be replaced by a professional technician.
  5. Check the wiring: Check the wiring and connections, ensure that all the wiring is securely connected and that there is no damage to the wires.
  6. Check the fuses: Make sure that all the fuses are working properly and that they are not blown or tripped.
Keep in mind that attempting to repair an AC/Heater unit can be dangerous if you are not familiar with the proper procedures and safety precautions. It's best to let a professional technician handle the repair. If the problem persists, it's recommended to contact the manufacturer's customer service or a professional technician for further assistance. They can inspect the unit and determine the cause of the problem and provide a solution. Regenerate response
1/17/2023 11:47:26 PM • Frigidaire... • Answered on Jan 17, 2023
Frigidaire dryer showing the world"loc" & won't start
The control panel lock is engaged. This keeps the dryer from being turned on by accident while cleaning the panel (or by a small child). There should be a line with a padlock symbol between two buttons on the control panel indicating the ones to press and hold to toggle the lock feature. On some Frigidaire dryers, the buttons to press and hold are Options and Select. You need to hold the buttons for 10+ seconds. The LOC message should disappear when you have held the buttons for long enough. However, if you do not release the buttons, the lock will toggle back on. I hope this helps. Cindy Wells
11/14/2022 11:52:05 PM • Frigidaire... • Answered on Nov 14, 2022
Frigidaire GLEH1642FS Front Load Electric Laundry Center. 3.1 cu. ft Washer and 5.7 cu. ft. Dryer Capacity, 16 wash cycles, Stainless Steel Dryer Drum, Energy Star, Stainless Steel Wash Basket, Tumble Care Cleaning System, Sound Silencer Plus, precision Dry Moi Logo
Popular Tags
1 questions posted
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
double stack frigidaire washer very
  • Dryers
