20 Most Recent
Epson LX-300+ II Matrix Printer Questions & Answers
Good day, we have a
Make sure the picture is at least as big as the logo to be printed and no lower than 300dpi, there really is no upper limit on quility but these should print OK.
Hi there! I would like
Could you possibly print 2 to the page. You may have to change the top margin so it wouldn't take more than half sheet. Just a though. Hope this helps!
Epson Status Monitor 3 :
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Hello guys, how can i change the LX300-ii font spacing. thanks in advance.
You can download user's manual where it explains how to use your printer's control panel to change one of 6 inbuilt fonts. read this short tutorialhttp://maintenanceprinter.blogspot.com/2011/07/how-to-change-fonts-in-epson-lx-300.htmlDownload manual:
Descargar Epson LX 300 III guess you can change fonts using control characters but I don't know if you can embad tham in a word doc. No way to test it because I don't have this printer.I remember having done it in early days of DOS word processing with Wordstar.Hold ALT and type the command character - the numbers 27. In notebook will look like an arrow to the left, followed by writing a command character, examples:? P Selects 10 cpi? M Selecting the 12 CPI? ? Select dense Print - 15 CPI (this character is typed by holding the ALT key figures 15)
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below.
1. Turn off the machine, and unplug the power cord of the machine from the power supply.
2. Open the paper output cover.
Remove the paper on the front tray if any.
Important:
Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper.
If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper.
When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed.
If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
