20 Most Recent
Whirlpool 24 in. DU951PWB Free-standing Dishwasher Questions & Answers
D/W not running
Roger, this sounds like a clogged pump or a bad motor. Not something you're going to be able to do yourself. I have the same general unit and I bless it every day that it works.
Wonderful Whirlpool Washus Interuptus!
My plan was to see if I could find you a service manual, but strangely, the only reference to that model number is your post here! My guess is the D6 is 'D for Dishwasher' and 'Series 6' or 6 models in that current series.
If the machine has been laid up or little used, check all the connection on the control board. Clean pins and plugs with electrical switch cleaner
https://www.google.com/search?q=DU940QWD6
8/26/2023 5:52:50 PM •
Whirlpool...
Answered
on Aug 26, 2023
How would I get access to whirlpool dishwasher pump?
Miniplayer (i)
We'll also want to shut off the inlet watersupply and disconnect that as well.
0:30/8:42
Please refer to youtube " Whirlpool Dishwasher Repair - How to Replace the Pump (Whirlpool # W11032770) "
3/23/2023 7:01:32 PM •
Whirlpool...
Answered
on Mar 23, 2023
My whirlpool dishwasher model # WDT780SAEM1 makes a loud popping noise when I open and shut the door. What is causing it and how do I fix it?
The loud popping noise that you're hearing when you open and shut the door of your Whirlpool dishwasher (model # WDT780SAEM1) is most likely caused by the door gasket. The door gasket is the rubber seal that runs around the door, creating a tight seal when the door is closed.
Here are a few things you can try to fix the issue:
- Check the gasket for damage: Inspect the door gasket for any tears, cracks, or other damage. If you find any damage, you will need to replace the gasket.
- Clean the gasket: Over time, debris and food particles can accumulate on the gasket, causing it to become stiff and not seal properly. Clean the gasket with a mild detergent and warm water, and then dry it thoroughly.
- Check the door alignment: Make sure that the door is properly aligned and not hitting the gasket when you open and shut it. If the door is not aligned properly, you will need to adjust it.
- Lubricate the hinge: If the door gasket is in good condition and properly aligned, the problem may be with the hinge. Try lubricating the hinge with a silicone-based lubricant, as this can help to reduce friction and noise.
- Contact Whirlpool: If you have tried all of the above steps and are still unable to fix the issue, contact Whirlpool customer service for further assistance. They will be able to provide you with additional troubleshooting steps or advice, or they may need to send a technician to repair or replace the dishwasher.
It's important to note that if the popping noise you're hearing is accompanied by other symptoms, such as leaks, then it may be related to a different problem, and you should contact Whirlpool customer service or a professional service technician for further diagnosis and repair.
1/14/2023 1:48:41 AM •
Whirlpool...
Answered
on Jan 14, 2023
Whirlpool gold quiet partner iii soak and scour indicator light on won't start
Es posible que la luz Soak & Clean del lavavajillas Whirlpool Gold Quiet Partner III no se encienda si el lavavajillas no est? recibiendo energ?a o si el lavavajillas no est? en el ciclo correcto. Se recomienda verificar la fuente de alimentaci?n y asegurarse de que el lavavajillas est? enchufado y reciba energ?a. Si la alimentaci?n est? conectada y el lavavajillas est? en el ciclo correcto, entonces es posible que haya un problema con los circuitos o el cableado del lavavajillas. Se recomienda ponerse en contacto con un centro de servicio autorizado de Whirlpool para obtener m?s ayuda.
1/6/2023 2:20:04 AM •
Whirlpool...
Answered
on Jan 06, 2023
