20 Most Recent Kenmore HE2t 3.7 cu. ft. Front Load Washer Questions & Answers
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon perhaps the element isnt getting power did it trip your circuit breaker some times the htc fails all you get is machine stop because the heater is not detected if it spins rinses and empties in a timely manner then all thats left is the heater system
1/10/2015 11:31:45 AM • Kenmore HE2t 3.7... • Answered on Jan 10, 2015
I have a kenmore he2t washer that will not start. Door locks, buzzes for a minute then shuts off. No error codes. What could the problem be?
the door interlock is basicaly a heated switch it locks then hold it locked but there is a sensor to check its closed in the first place i think the interlock sensor isnt right replace the door interlock is the first step http://www.ebay.co.uk/itm/WHIRLPOOL-SPORT-MAYTAG-EPICZ-KENMORE-HE2-Door-Lock-W10253483-46197023640-8540772-/141476775106?pt=LH_DefaultDomain_0&hash=item20f0ac44c2 here is one i found on ebay its not cheep so shop around a bit now you know a few equivelant types .,.. and models
12/9/2014 12:19:42 AM • Kenmore HE2t 3.7... • Answered on Dec 09, 2014
I have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still does it
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
3/19/2014 3:12:46 PM • Kenmore HE2t 3.7... • Answered on Mar 19, 2014
Lights flashing during cycle
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put everything back... this should fix the issue.Before you re-fit the filter check to see that the blades of the pump further inside are turning well - no blocks. If the prob still persists you must examine pump.http://www.youtube.com/watch?NR=1&v=4IBvHbQ_3pA&feature=endscreenIf helped click helped.
1/9/2014 5:02:51 AM • Kenmore HE2t 3.7... • Answered on Jan 09, 2014
Leaking hose part no. 1344559
if is leaking by the hose repair or chage and adjust very well the clip or replace because loose the pression.God bless you
9/30/2012 10:50:31 PM • Kenmore HE2t 3.7... • Answered on Sep 30, 2012
0answers
Wash Cycle will not start; add garment and door locked lights on.
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
5/17/2019 11:44:46 AM • Kenmore HE2... • Answered on May 17, 2019
Leaky drain hose
https://www.youtube.com/results?search_query=replacing+model+110.4756+drain+hose. click on this link and review numerous videos you find there and although you might not find your exact model you will find enough info to do your replacement
1/15/2018 6:52:16 PM • Kenmore HE2... • Answered on Jan 15, 2018
0answers
I have an HE2 Model 110.47571601. The power will
There are two control boards (parts 3 and 6) shown here: http://www.searspartsdirect.com/model-number/11047571601/0582/0153200.html . Make sure to look at the Control Panel diagram. Part 3 is http://www.searspartsdirect.com/part-number/8540490/0026/110.html?modelNumber=11047571601&categoryName=Residential%20Washers&brandName=KENMORE . Part 6 is http://www.searspartsdirect.com/part-number/W10022320/0026/110.html?modelNumber=11047571601&categoryName=Residential%20Washers&brandName=KENMORE . With these part numbers, you should be able to find them online. They will be listed as Whirlpool or Whirlpool OEM parts. If you add a comment with the problem that led you to have a technician look at the washer, I will confirm which board is which. I suspect part 6 is the B board but I'm not certain of that. I hope this helps. Cindy Wells
4/20/2017 10:03:11 PM • Kenmore HE2... • Answered on Apr 20, 2017
I replaced the drain pump and now if I try to start machine all I here is drain pump humming. It wont fill or cycle. still have a F21 code
Have you looked into the water level gauge? It may be stuck
6/25/2015 1:41:03 AM • Kenmore HE2... • Answered on Jun 25, 2015
Kenmore HE2t 3.7 cu. ft. Front Load Washer Logo
Popular Tags
32 questions posted
Alexander
vince
View Most Popular
HE2 Kenmore
  • HE2 Kenmore
Most Popular Question
leaking hose part no 1344559
  • Washing Machines
