20 Most Recent
LG WM0742HGA Front-Load Steam Washer with 4.2 cu. ft. Capacity, 9 Wash Programs, 6 Temperature Levels, Spin Speed of 1,200 RPMs, Allergiene Cycand Rear Controls, 27, Pearl Grey Color, ChiLock, SeDiagnosis, Auto Balancing, Auto Sud RemovaForced Drain Sys Questions & Answers
Hose from the tub to the pump is blocked, how can i clean it?
I think that you will need to go in either through the back or base and I think the base is more likely. Just bear in mind that there's only limited access so it's going to be tight in there. Also, although you may be able to get the hose off it may be considerably more difficult to get it back on. You may also think about getting a technician to look at it - but get a quote first.
My lg wm0742hga front load washer machine over fill of water causing to leak out from the door
even when overflowing it shouldnt leak from the door? less u have a bad door seal? the water problem may be due to a bad water inlet valve? have u notice water in the tub even when ur not using it? check with a multimeter the inlet valve and the water pressure switch? blow into the water pressure switch while it is in the wash mode filling with water and if it starts washing the diaphfram is good if not its faulty. u can also checl the water inlet valve the one with the hoses attached . by running either a hot or cold cycle only and turn off the hot then turn off the cold? see if it continues to over flow with each cycle? hot then cold- GOOD LUCKKKKK
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
