20 Most Recent
Whirlpool AWM6120 Front Load Washer Questions & Answers
Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
6/14/2020 11:08:05 AM •
Whirlpool...
Answered
on Jun 14, 2020
Flashing lights on Rince, Start & 0 speed.
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
12/13/2017 7:27:14 PM •
Whirlpool...
Answered
on Dec 13, 2017
AWM 8121 NOT DRAINING OR SPINNING PROPERLY
that isn't a good model number,open the door,look around the opening where you put the clothes in and next time send the model number off of the machine,if you can't get it to drain and water is in the machine get a shop vac,suck out the water from the tub,then go to the pump,loosen the center of the pump until water starts to come out vac it up until no more water comes out,remove the center catch and see if there's junk in there,if so this is your problem,stick the nozzle of the vac inside and clean out the inside,put it back together and see if it will drain
9/30/2017 1:02:55 AM •
Whirlpool...
Answered
on Sep 30, 2017
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
1/11/2014 8:54:02 AM •
Whirlpool...
Answered
on Jan 11, 2014
No spin cycle
have you tried unblocking the inlet and outlet pipes under the drum
1/7/2013 6:43:06 AM •
Whirlpool...
Answered
on Jan 07, 2013
My washer is not showing any error codes just
If the door is closed the 'door open' indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
3/9/2011 1:39:41 PM •
Whirlpool...
Answered
on Mar 09, 2011
Door seal leeks. The rubber
Sounds like your bellows is worn and has begun to leak. Here's the way to change it...
The bellows will have a retaining wire on both the front panel and plastic tub interfaces. You need to remove the front panel wire first. Simply pull the lip forward until you can see the wire. Use a pliers or screwdriver to remove it. Peel the bellows off of the front panel and you can see the attachment to the tub. Same removal technique.
Be very careful when installing the new bellows to be sure it is seated fully and correctly all the way around the tub. Reinstall the retaining wire. Same installation technique for the front panel.
Good luck.
1/20/2011 8:16:06 AM •
Whirlpool...
Answered
on Jan 20, 2011
After each cicle of washing its coming on the
Whirlpool AWM6120
There are several items which may contribute to your issue at hand.
A plastic gasket seals the front to back portion right above the location where deprey gets caught when in wash cycle. When this builds up with trash and gunk not caught by the filter, it will cause water to leak out and eventually onto the floor. You may also have a build up in the drainage hose backup and release for dirty water. Check this area thoroughly!! You can also see exactly where the water is dripping so that we can identify what is the root cause of the water leak. Nothing sounds major so replacing the unit is not a good idea and would be expensive.
1/12/2011 8:49:45 PM •
Whirlpool...
Answered
on Jan 12, 2011
