20 Most Recent
Whirlpool LSR6334LQ Top Load Washer Questions & Answers
Timer not working
Sounds like a bad timer motor. The entire timer will need replacing.
6/26/2014 5:23:52 AM •
Whirlpool...
Answered
on Jun 26, 2014
All the water does not spin out of the clothes
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
6/7/2011 3:30:12 PM •
Whirlpool...
Answered
on Jun 07, 2011
Only washes when it gets to the rinse it stops
The most common cause of the symptoms you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that may not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are tight. Sometimes these screws will loosen, causing the lid switch make intermittent contact. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list, include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. If the model number is correct, the lid switch is listed as item 11 (part number 3949247) under the "Top and Cabinet" parts listing. The lid strike (actuator) is listed as item 20 (part number 358684).
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid strike (if equipped) usually costs less than $5. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
12/22/2010 10:46:18 PM •
Whirlpool...
Answered
on Dec 22, 2010
Hi Daniel S. My Whirlpool
Hi
When everything else in washer works fine however, it won't spin then it indicates that the washer is unable to drain. You should check the drain hose and the drain pump filter for any clogs and obstructions. If its clean and the issue returns then check the drain pump operation, if its not working then its should be replaced. Hope this helps...please post back for further assistance.
Daniel
12/8/2010 9:11:22 AM •
Whirlpool...
Answered
on Dec 08, 2010
My whirl pool type 111
Hi
further assistance.
Daniel
12/7/2010 8:29:18 PM •
Whirlpool...
Answered
on Dec 07, 2010
Whirlpool washer type 111
we have a whirlpool LSN1000AQ0 and machine wont spin on its own without turning it by hand to get it started.
9/20/2010 1:44:22 AM •
Whirlpool...
Answered
on Sep 20, 2010
