20 Most Recent
Whirlpool GSX9885J Top Load Washer Questions & Answers
Will not spin
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
2/22/2011 2:38:06 AM •
Whirlpool...
Answered
on Feb 22, 2011
I have a whirlpool gsx988jq0
Hi type washing machine does not unite Pelt
There Kepler
Between the motor and Transemsin and change will find it very easy
D & L in stor
11/22/2010 4:19:21 PM •
Whirlpool...
Answered
on Nov 22, 2010
It give me an code F4 and nothing works
F4 is typically related to a drainage problem.
If the water is not draining from your dishwasher, verify the following:
Verify that there is not a clog in the drain hose or air gap. This is typically the reason that a dishwasher won't drain and the clog is usually where the drain hose attaches to the garbage disposal or sink drain pipe. Remove the hose and clear any clogs, then reinstall.
Verify that the pumps drain impeller is working. You can reach the impeller from inside the dishwasher after removing the lower rack, spray arm, and arm support. This typically involves removing a few screws. Once upper parts are removed, inspect the drain impeller, which pushes the water toward the drain port, for any cracks or missing blades. If the impeller is defective, the water will not drain properly and you would need to replace it. Inspect the sump area for any debris or broken glass that could be blocking any ports.
Verify that the drain valve is working; many are controlled with an electric solenoid that opens the valve, sending the water to the drain. There is a chance that the solenoid or the diverting lever could be stuck which would prevent the water to drain. If so, try to free up the solenoid and lubricate the lever. Otherwise the solenoid or pump assembly may have to be replaced.
Verify that the motor is turning/ working and verify that there is power to the motor. If the motor hums but doesn't turn, it may need to be replaced. Motors can get stuck if not used regularly. If the motor is defective, the water will not drain and you would need to replace it.
There are ways to test the pump and motor with a multimeter. If you are not comfortable with doing this, you may want to have a plumber test it for you.
2/17/2010 3:09:50 AM •
Whirlpool...
Answered
on Feb 17, 2010
Whirlpool GSX9885J Unable to select cycle
Beeper will sound continuously while error code is flashing if that is not so then the issue is with the control board. IF the machine is in warranty call the company guys.
Thanks
K
6/16/2009 4:09:40 PM •
Whirlpool...
Answered
on Jun 16, 2009
