20 Most Recent Whirlpool LTE5243D Top Load Stacked Washer/Dryer Questions & Answers
Before wasting money on a timer that wont be returnable once it is removed from the packaging please respond to me and tell me does the washer do everything including draining, and the only thing it will do not do is spin
or will it wash but not drain and spin
their are 2 posibilities based on your response and neither is the timer
Thanks,
Gene
so ya know i have beena appliance repair technician for over 30 years
Whirlpool... | Answered on Feb 05, 2019
First be sure you're getting power to the motor this could cause both problems. If getting power then
sounds like you have 2 problems.
Dryer
On the heating problem be sure you have 220 volts at the power block, check the heating element , thermostats & high temp cutoff with an ohmmeter. Also check the centrifical switch on the motor it keeps the heat off for safety till the motor is up to speed so the fan is working.
Washer
Check lid switch some machines won't do anything but fill with the lid open . To check lid switch push the the switch down with a small screwdriver. If switch is ok check the coupler between the motor & transmission it can cause no agitate or spin. If all these are ok you may have a transmission problem. Last resort may be timer or wireing.
Whirlpool... | Answered on Nov 22, 2017
you can't do that,why didn't he just run a 240 volt plug to the dryer
Whirlpool... | Answered on Oct 07, 2017
you might have broken something else off of the timer go here
https://www.repairclinic.com/PartDetail/Timer/WP3946432/4434024
is the white part still on timer shaft?this is the piece that the indicator knob slides onto so it's not loose and free spinning,i looked up your model and the indicator knob is no longer available
www.searspartsdirect.com/model-number/LTE5243BN0/1198/0152000.html?searchType=modelSearch&q=LTE5243BN0&searchTerm=LTE5243BN0
go here and you can see your machine
The tub has simply came off the struts. Best fixed by two people-- one to help hold the tub in position, and one to twist the strut(s) back on-- through the bottom of the unit.
Whirlpool... | Answered on Jun 13, 2017
Your most likely suspect is the "ATC" switch... it is the only part that can interfere with the operation of the valve. ATC stands for automatic temp. control: Whirlpool Washer Dryer Combo Temperature Control Switch WPW10114118
They suck!
Whirlpool... | Answered on Apr 25, 2017
Try shutting off the hot water valve on the plumbing and start the washer with a warm water setting. If you get no cold water, check to see of the cold water hose is plugged with debris, if not the cold water valve may have a broken or disconnected wire. or the valve may have failed. Hopefully it is just a plugged hose.
Whirlpool... | Answered on Apr 29, 2014
If nothing is working at all it is probably the timer switch (dial you turn) they die. Not too expensive to fix. If you are comfortable with tools you can very likely do it your self. I know this because I paid a service to do it. When he was done, I went - Huh, that's all there is to it? It is just above Lego. If I remember correctly it took him less than 15 minutes to do it but I of course had to pay the minimum service call charge.
So just find a YouTube video for changing timers and you'll see what I mean.
Of course if it is not the timer you just wasted time and money.
I don't know how to confirm if it is the timer that is broken. Perhaps there is a diagnostic video....
Good luck
B
Whirlpool... | Answered on Apr 19, 2014
I'm not familiar with your model but on the surface it sounds like the belt is loose. If the load is not really well-balanced, a loose belt can't move the drum and when the load is balanced the motor turns really fast because the belt is slipping. Tightening or replacing the belt is fairly simple with normal tools and there are plenty of pages/videos out there on how to do it. Hope this helps! Good luck!
Whirlpool... | Answered on Apr 05, 2014
I wouldn't know as you are asking this question in vacuum section
Whirlpool... | Answered on Jan 26, 2014
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
316 questions posted
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
dryer knob whirlpool heavy duty thin
  • Washing Machines
