20 Most Recent Whirlpool Ultimate Care II LSQ9564J Top Load Washer Questions & Answers
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Whirlpool... | Answered on Sep 10, 2018
Have you cleaned the water filter out and checked the waste hose first? Make sure you only use a quality detergent as cheap pound shop stuff can rot the sensors, and foul up the camshaft.
Whirlpool... | Answered on Feb 04, 2018
indicates a problem in the timer control
that type of controller suffers from burnt points
have a technician check it out and replace it
Whirlpool... | Answered on Dec 14, 2017
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Whirlpool... | Answered on Nov 01, 2017
If timer doesn't move through entire cycle, timer is bad. Only exception to that is if lid switch is bad.
Whirlpool... | Answered on Sep 09, 2017
Sounds like a lid switch problem
Whirlpool... | Answered on Aug 23, 2017
replace the lid switch. that's what i have to do with mine. i researched it a few weeks ago. Simple cheap fix - i think it was about $20
Whirlpool... | Answered on Mar 09, 2017
The problem might be motor is short circuited kindly replace the motor to solve your problem
Whirlpool... | Answered on Jul 23, 2016
usually a transmission problem or program is not setting it to final spin which is higher speed
Whirlpool... | Answered on Jan 18, 2016
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Whirlpool... | Answered on Sep 19, 2015
Does unit have a reset button? If it has manual control for cycle did you try going clockwise to the start position and then restarting?
If she stopped the cycle by opening the door perhaps that switch is still stuck in an open position.
Whirlpool... | Answered on Aug 31, 2015
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
1,616 questions posted
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
whirlpool awm312 3 front loader washing
  • Washing Machines
