20 Most Recent
Whirlpool GBS277PDS Electric Single Oven Questions & Answers
How to get the glass front back on oven door of Whirlpool range
Ok. Heres what I was dealing with....Dissasembled. NOW (after you scrubbed everything to your liking try this.1: With the door laying "oven" surface down on a flat surface. Gently place glass sheet/pane down squaring it up evenly as you can.2: (Might sound strange) Grab the door handle and reposition it where it needs to go and slide the glass in the "ledges". Even everything up square as possible. Insert screws(2), but do NOT tighten all the way.3: Now you have 2 (L & R) uprights. Insert "handle" end of uprights first, then align carefully the "tips" into the holes, and then snug the oven handle screws.4: Carefully align the metal "base" channel/seat with the glass so the window/glass seats on the bases slots/shelves. Align all holes and insert screws (4 - 2 screws on both sides of base), finally align the center screw and tighten snug.5: Replace door on Range Unit ande get cookin again!!Hope this helps. I think its a poor design to let anything inside the door. Nice Range/Oven unit. Just a bad door design in my opinion.Oh Yeah. The door hinges only took me 4 months to figure it has built in hinge locks. THEY are VERY convenient and once you know how they work. They are an AWSSOME invention for what they do!!
1/19/2013 6:30:27 PM •
Whirlpool...
Answered
on Jan 19, 2013
Whirlpool Gas Range SF357PEKQ0 -- over heats; will
Hi lkanderson97,
This error code F3:E2 means that Oven temperature is too high (Cook mode). The only way to resolve this issue is to replace Oven temperature sensor (RTD). This part can be replaced by your husband. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call. Once you got the part instruction is also provided on how you'll replace the sensor.
Hope this helps.
Thank you for using FixYa.
6/6/2011 2:14:08 AM •
Whirlpool...
Answered
on Jun 06, 2011
How do i reset my bauknecht oven clock?
This is what worked for me:
1) hold down the "Select" button for 5 seconds till the display starts flashing
2) use the right hand dial to set the hour
3) press the "Select" button
4) use the right hand dial to set the minutes
5) press the "Select" button
10/6/2010 6:31:00 PM •
Whirlpool...
Answered
on Oct 06, 2010
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
6/2/2010 6:57:04 PM •
Whirlpool...
Answered
on Jun 02, 2010
Oven elements will not heat
theres a thermostat on the back wall that problaby blew out as a result of surge,its wired in line with both bake andbroil element
5/3/2008 8:23:13 PM •
Whirlpool...
Answered
on May 03, 2008
Whirlpool YWFE710H0BS0 oven no longer heats up.
Check the elements for continuity with a multimeter. Sometimes the connectors draw too much current and can burn out as well. Both are easy tests. A runaway temperature can make elements fail because there is no thermostatic control, they just glow bright yellow..
What does E1 F2 code means?
Greetings,
This might indicate a bad keypad or that the cable connecting the keypad to the chip board within your whirlpool has come loose. You might need to work with whirlpool to see if they keypad needs replacing or if the internal chip board itself is faulty.
Thank you.
