20 Most Recent
Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Questions & Answers
When i turn on my tv it will automatically turn off by itself after 30 seconds.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
7/14/2016 8:57:42 AM •
Samsung...
Answered
on Jul 14, 2016
Where is hdmi port
If a new set it is somewhere on the back. Check your manual for exact location.
2/15/2016 2:04:50 AM •
Samsung...
Answered
on Feb 15, 2016
What could be wrong with my Samsung tv un46d6000sfxza
If I had a dime for every one of these type of questions I could retire without my pension. The problem with these sets today is that they no longer fall under the category of "durable goods" which include washers, dryers, water heaters, furnaces, etc. They now come under the electronics category. This means that you shouldn't really expect these devices to last much longer than their warranty period. The days of TV sets lasting 10-15 years are over. Three to five is the new norm. They are designed with obsolescence in mind. The manufacturers do not build any tolerances into the electronics so any small power surge or glitch can cause a cascading failure through the device, taking out multiple board with it. You replace one, it works a few minutes, and then it gets blown out by another one that was bad as well. By the time you get through replacing all the boards, if you are lucky enough to get it working again, you find that for a buck or two more you could have bought a new one that was larger and with more features. This is the manufacturer's plan. If TVs lasted 10 years, then they can't keep selling them at the rate they can build them now. If you want one of these to live a little longer than normal, invest the hundred bucks or so into an UPS to attach to it for power and surge suppression. Dollar store surge protectors won't do much to save these touchy devices.
11/22/2015 5:29:27 PM •
Samsung...
Answered
on Nov 22, 2015
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
