20 Most Recent Dometic 3106995.032 Analog Thermostat Heat Cool 3107612.008 Questions & Answers
should have a internal sensor could b out of range or connection issue between it and t-stat.
Dometic... | Answered on Aug 23, 2015
relay module and t-stat issue with communication cable.
Dometic... | Answered on Aug 18, 2015
download it from dometic corp.
Dometic... | Answered on Aug 16, 2015
If you don't use the heat pump don't install a heat pump t-stat. But if you do use a ht. pump tstat you should be able to leave that wire off (the O wire) and it will function properly.
Dometic... | Answered on Jun 23, 2015
What type of RV is this in?
Dometic... | Answered on Jan 27, 2013
the other 2 units possibly have heat strips if not turn off the main unit should control furnace switches in power box or on control board
Dometic Heating... | Answered on Nov 23, 2019
make sure fan on auto and unit on heat if ok check heat strip
Dometic Heating... | Answered on Oct 19, 2019
Need to go up there and give more info. Look for outdoor fan...Is it spinning? Compressor on? Could be dual capacitor as they are 50% of problem lately
Dometic Heating... | Answered on Aug 22, 2019
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
Dometic Heating... | Answered on Aug 17, 2019
It sounds like your Dometic unit is not getting power despite the breaker being on. Unless the Dometic unit has an internal fuse to check, I would get out a volt/ohm meter and check to see:
1. Is there power coming out of the breaker that goes to the ac unit?
2. Is there power at the terminals of the ac unit? (You can sometimes remove a ceiling cover to access the contacts on the on off switch.
Lastly is your RV hooked up to full power with two 110 volts on both legs beside the neutral and ground wire? If you are only feeding your RV with a standard 110 volt extension cord and using an adapter, that can mean half the circuits in your RV are energized while the other half 110 volt leg is not. You must energize the second leg by using a full 30 amp or 50 amp dual power cord.
RV's are funny. They require two 110 volt legs with a neutral and a ground. The two 110 volt legs are both of the same phase. There is no 220 volts between the two hot legs as they are in phase. A volt meter between the when hot would read zero volts, while each hot leg to neutral would read 110 volts.
Hope this helps.
Dometic Heating... | Answered on Aug 10, 2019
Dometic 3106995.032 Analog Thermostat Heat Cool 3107612.008 Logo
10 questions posted
Top Dometic Heating & Cooling Experts
Bill Long
Thomas F. Schneider
John Tripp
John Tripp
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Heating & Cooling
Most Popular Question
bought new thermostat horse trailer old
  • Heating & Cooling
