20 Most Recent
Whirlpool GBD277PD Electric Double Oven Questions & Answers
F2 error code
F2 E6 says this:
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
3/20/2013 7:32:31 PM •
Whirlpool...
Answered
on Mar 20, 2013
Oven will not stay on have error code e6 f2
F2 - E6
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
5/5/2011 1:25:49 PM •
Whirlpool...
Answered
on May 05, 2011
OVEN CUTS OFF POWER
no.. mm/ if this does not help then more info is needed like model/ brand / and the real problem your having ..
7/15/2010 8:30:48 PM •
Whirlpool...
Answered
on Jul 15, 2010
My oven keeps beeping and
Troubleshooting Common Problems If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then check your fuses and your door switch. If the internal fuse or thermal fuse is blown you will need a professional to help you replace it. You should also check the door hooks and the door release button. If they are broken, your microwave will not work. If your microwave looks and sounds normal but isn?t producing any heat, you should check the internal door switches, the high voltage circuitry and the circuit board for problems. You will need a certified technician to help you make these repairs. If you are unable to adjust the power level, there may be a defective triac or a problem with the circuit board. If the carousel inside your microwave won?t turn when you run it, the small motor that operates it may be broken. If the display flickers but it does not affect how the microwave heats, then you don?t need to worry about it. But if you are having display flickering and it is affecting the way your microwave operates, you may have a more serious problem in the microwave cabinet. If your microwave buzzes loudly and produces no heat you probably have a defective power diode, magnetron or high voltage capacitor. These are all things that can be replaced or repaired by a qualified technician. These are just a few common microwave problems that you may face and what the likely cause is. You will ultimately need to take your microwave to a qualified, certified repair shop to have it fixed if there is something seriously wrong with it that is causing it not to heat or function properly.
6/19/2010 5:02:51 AM •
Whirlpool...
Answered
on Jun 19, 2010
Oven gives code E6 F2 on panel
The problem in our oven has cleared by itself. I did see the E6 F2 error message but for now, it's working fine. Considering the customer service was only able to help to the extent of reading the error code sheet the same as I was (the sheet is behind the touch pad) and seeing how limited the solutions were, we don't think we'll be buying another Whirlpool. I was pretty insulted when the girl a customer quality called to offer me part #8300453 at half cost of $164 providing I have a service guy look at the stove and call in the part. On top of that, the warrenty is 90 days and the part is on back order. Why would the part be on back order? A) they either did not make an ample supply for inventory, B) there are many ovens needing this part. For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me someone was sleeping with a cigar in their mouth in Quality Control. Or, learning what that meant.
Enjoy the day!
Robert
5/22/2010 2:11:48 PM •
Whirlpool...
Answered
on May 22, 2010
The digital display no longer lights up. How do I
if your oven works correctly and the only thing that is wrong is that the digital display is blank you will have to replace the control board remove the two screws on the side rails lower remove them set them aside remove the two screws in the side of the of the control panel pull up on it and lean it down take the screws out of the control board and disconnect the wires one at a time and put them one at a time on the new control board reassemble the unit that will complete the replacement
4/4/2010 6:42:12 PM •
Whirlpool...
Answered
on Apr 04, 2010
Bottom half of my Ikea
If the fan is working o/k, then it it is more than likely the fan oven element has failed.
You should find the element located behind a removeable cover at the rear of the oven compartment
The only way to test it properly is with a meter.
Do this with the meter set to continuity, you should get a full scale deflection if element is o/k.
No reading, then element is faulty.
Sometimes it is possible to see where the elemen t has blown, but not in every case, so do not rely on a visual inspection.
I am basing my solution on the basis that the oven is heated by electric and not gas..
Good luck.
Please rate my solution.
Thankyou.
2/27/2010 10:46:17 PM •
Whirlpool...
Answered
on Feb 27, 2010
Nothing is working
There are fuses on/in the stove... you need to locate the access panel and check them.
Robert
5/20/2009 6:48:53 AM •
Whirlpool...
Answered
on May 20, 2009
