20 Most Recent
Amana GMH950453BX Gas Furnace Questions & Answers
Amana AMH95 Blown control fuse
Control fuses only blow with a 24 volt problem. Make sure that you replace it with a fuse NO LARGER than 5 amps.You could have a thermostat wire pinched or some wire touching the cabinet inside the unit, but it is a 24 volt problem.
12/9/2014 4:51:06 PM •
Amana...
Answered
on Dec 09, 2014
Furnace won't turn on or blow
make sure thermostat is calling for heat if so check safety circuit starting with the fuseable link if ok check to see if gas valve has voltage if so bad valve if not keep checking the safety circuit
10/15/2014 2:50:13 AM •
Amana...
Answered
on Oct 15, 2014
Funace willnot stay lit
Sounds like you may have a dirty flame sensor. Try cleaning it with steel wool or Emory cloth.
7/30/2014 2:12:13 AM •
Amana...
Answered
on Jul 30, 2014
Re ignight
Believe that is hot surface ignition...so it should relight itself. turn the power off & back on, the power outage could have messed with the circuit board
12/6/2013 11:37:17 PM •
Amana...
Answered
on Dec 06, 2013
I'm not getting any code after installing a control board for my Amana ptac?
Does the power light come on?
If yes, then you can do a reset as below:
There is a master switch on the bottom left of the control board. Slide that to 'off' position.
Then press the hot and cold switch/key together and then slide the master switch back to 'on'.
Please put your response/observation here if that does not work or there is power light as asked on top.
Thanks
Amana PTH153B50AM PTAC where the heat runs intermittently.
i'm not familiar with your specific unit but ..sounds like an electronic gas value has gone bad or has a bad connection when that happened to my friend it wasn't that expensive to have it fixed .. BYW it acted like this for a while then stopped working completely
