20 Most Recent
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Questions & Answers
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
How can I get it to empty out the extenal drain?
might your hose or drain fitting be clogged , if so it's a very common cause of no drain, i use a wet/dry vac backwards (blowing out) to gently push whatever it is out of the hose and fitings , wet /dry vacs have a gentle air flow not sharp/rough like compressed air !!! to make a messs on your floor
Keeps beeping but won't start
I can't take credit for the solution to the fan problem, but I can attest to its merit. It turned out to be my problem too. The fan bearings dry out making it harder to start. This drives more current through it and this burns out the thermistor. If you do the fix here make sure you oil the fan bearings too. http://www.fixya.com/support/t3588983-lg_lhd65ebl_serial_603taac20984
When I turn it on
Try unplugging it for at least an hour. Over night would be better. By then, it should have lost any stored memory it has.
