20 Most Recent Danby DDR2506 Dehumidifier Questions & Answers
7answers
P1 and P2 error codes
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
9/3/2022 1:08:00 AM • Danby DDR2506... • Answered on Sep 03, 2022
0answers
E6 error
Be the first to answer 1/9/2016 12:59:37 PM • Danby DDR2506... • Posted on Jan 09, 2016Be the first to answer
2answers
P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
7/10/2015 5:33:47 PM • Danby DDR2506... • Answered on Jul 10, 2015
0answers
0answers
Humidifier
Be the first to answer 5/28/2013 4:01:54 AM • Danby DDR2506... • Posted on May 28, 2013Be the first to answer
What does P2 mean. It
Take it to a safe place and blow it up
10/25/2012 8:04:37 PM • Danby DDR2506... • Answered on Oct 25, 2012
0answers
P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
E2 = Not draining
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
5/22/2009 4:47:02 PM • Danby DDR2506... • Answered on May 22, 2009
Zip tie stuck inside Danby dehumidifier
Not a problem, they are full of plastic.
6/14/2023 3:14:09 AM • Danby... • Answered on Jun 14, 2023
Dehumidifier doesn't turn on
The water in your sump pit needs to be no more than 2-3 inches, this is enough to keep your pump happy and make sure it works properly when you need it to. Equally, the pump should start to work when the water level is still 6-7 inches below the level of your floor. https://www.homoq.com/proper-sump-pit-water-level/
6/18/2021 4:49:02 AM • Danby... • Answered on Jun 18, 2021
My Danby dehumidifier leaks out
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
6/26/2020 12:55:13 AM • Danby... • Answered on Jun 26, 2020
I am looking for a manual for a Danby dehumidifier model DDR070BBCBD8. Where would I find one
try searching for " Danby dehumidifier model DDR070BBCBD8"
10/28/2019 6:49:27 PM • Danby... • Answered on Oct 28, 2019
I would like to get an owner’s manual for a Premier Danby R410A Dehumidifier
try looking here and using a search engine next time. https://www.manualslib.com/brand/danby/dehumidifier.html
10/28/2019 6:22:41 PM • Danby... • Answered on Oct 28, 2019
Danby DDR2506 Dehumidifier Logo
23 questions posted
Top Danby Dehumidifiers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
Danby Dehumidifiers
  • Danby Dehumidifiers
Most Popular Question
p1 error
  • Dehumidifiers
