20 Most Recent
Whirlpool GR450 Electric Kitchen Range Questions & Answers
Self cleaning mode door will
what is the model number off of the machine,open the bottom draw,look around the frame not the draw and you'll see a tag with the model and serial numbers,just need the model number,there's a door lock motor that could be bad,i can look it up for you,i don't understand what you wrote,what did the tech tell you?
Own a Whirlpool GR450LXHQ2 Convection oven. One
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Whirlpool cooker shows error code
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#@#$RWS
I am getting the E0 -F2- error code on my stove. I
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@!@
Error code E2 -F3- Everything works except the oven
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Whirlpool gas range diagnostic code E6 46 (cannot find this error code combination anywhere)
E6 46 is a diagnostic code for a Whirlpool gas range. This code indicates that there is a problem with the oven temperature sensor. The sensor measures the temperature inside the oven and sends this information to the control board. If the control board detects a problem with the sensor, it will display the E6 46 error code.
To troubleshoot the problem, you'll want to do the following:
- Check the wiring: Make sure that all of the wires connected to the oven temperature sensor are secure and not damaged.
- Check the sensor: The oven temperature sensor is located in the back of the oven, near the top. Make sure that the sensor is properly seated in its socket and that it is not damaged.
- Check the control board: If the wiring and sensor appear to be in good condition, the control board may be the cause of the problem. You'll want to check the control board for any visible damage or loose connections.
If you are unable to find the problem, I recommend having a qualified repair technician diagnose and fix the issue for you. Electrical issues can be complex and it's important to address them promptly to prevent further damage.
1/8/2023 1:32:12 AM •
Whirlpool...
Answered
on Jan 08, 2023
