20 Most Recent
PUR (FM-9500) Air Purifier Questions & Answers
Kitchen faucet purwaterfilter
the light has a battery that 's not replaceable. it wears out and then the light doesn't work any more. you just have to guess when it's time to replace the cartridge. (I got a new filter that i like the color better, after i used the old one for a while after the light ceased working). might be under warranty.
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Leaking at the base of the unit right below where it screws into
I've had the same problem with my 9600. Leaked no matter what I tried. The best thing to do is contact Pur at this address and explain your problem.
http://www.softcoin.com/p/handler?target=general&action=displayPage&sid=1650&pageId=252
Fill out the form and they will get back to you. Most likely they will send you a new unit.
