20 Most Recent
Yamaha Wave Venture 700 Waverunner Xl Raider Air Box Intake Silencer Questions & Answers
Waverunner wont stay on when cold
without more input its hard to say, sounds like carb gummed up, remove and clean bowl, valve n seat, when you remove bowl if foriegn material or strange color in fuel is found clean thouroughly with carb cleaner and reassemble according to specs
good luck n send a message if u need any more help If you need further help, I’m available over the phone at
https://www.6ya.com/expert/michael_00678fd4800d19c5
How do you adjust a carburetor?
carbs have fuel mixture screws (tiny ones made into some of the orfices on them..fuel injection is usually electronic..means a control module issue
Looking for part no 109143
where are you ? we brake jetski's and if we have not got one secondhand we can get new !! south coast of spain !
How much is a vintage low miles yamaha ex 650 worth
Two things depreciate faster than a car and they are boats and rvs. A vintage yamaha is a nice term for older yamaha. I will be worth what someone wants to pay for it. That said, if parts are still available and it runs well, no work needed, you may get $1000 to $2000 for it. But that depends on the area you are in and what other used ones are going for. All you can do is offer to sell it for some amount of money and see if anyone calls. Lower the price if no takers.
Need to know about a clicking noise motor won't turn over 97 Yamaha 75 horse boat motor
Most likely, (1) it's an old worn out battery, low charge, poor or corroded cable connections. Inspect and clean them. You may want to jumper battery with your car battery. If problem persists, (2) check starter solenoid connections and output connections. (3) As a last culprit, it could be a bad starter. And make sure your engine is not frozen. (Take spark plugs out and turn the flywheel by hand).
