20 Most Recent
Honeywell RTH230B 5-2 Day Programmable Thermostat Large Questions & Answers
My Honeywell RTH230B flashes a snowflake them the fan shuts off and
Hello, the snowflake flashing is a (supposed to be) 5 minute delay to prevent short cycling of the compressor. This delay can sometimes get stuck thus requiring replacement. To test , remove top of thermostat to where you can identify wires and terminals. Have someone stand near the ac unit for this test, and then take a wire or paperclip and briefly touch Rc to Y. This should start the outdoor unit. R to G will start the indoor fan
7/6/2019 11:23:37 PM •
Honeywell...
Answered
on Jul 06, 2019
My rth2300 honeywell thermostat says the heat is on but the heat is not on.why?
It could be the breaker is tripped or the blower is not getting power. Check your transformer to make sure you are getting 24 volts going to the fan relay sequencer and make sure you check your capacitor that is connected to the fan as well. sounds like a minor electrical hiccup. Also check your thermostat wires and pay close attention to anything marked w1 or w2 as these are the terminals that control the heating part of your system.
12/1/2014 3:30:27 PM •
Honeywell...
Answered
on Dec 01, 2014
Wont turn off a/c still works
You have to take the cover off and get inside and unhook a wire. You may have 3 wires unhook 1 and if that doesn't turn it off hook it back up and unhook the next. One of them will turn it off!! Then go to the hardware and get another thermos!! You won't get a shock or anything cause it's not hooked up to any power source, they are just sensor wires. I don't know much about Honeywell, I just know I don't like their thermos. Had one once and had nothing but trouble w/it !!
7/27/2014 9:04:58 PM •
Honeywell...
Answered
on Jul 27, 2014
Replacing a 2-pole baseboard heating thermostat
Here at home where I reside we have an old school thermostat that has the mercury bulb that acts like a sensor, and in other cases it could just be as easy as replacing the batteries in the unit itself, usually a lid that hides them, sometimes it works
1/29/2024 4:24:58 AM •
Honeywell...
Answered
on Jan 29, 2024
Hello, I have old Honeywell LR1620 thermostat. gas furnace and electric a/c. What options for a programable or non-programable Honeywell thermostat?
Here are some options:
Honeywell Home Non-Programmable Thermostats: These thermostats are designed for simplicity and comfort control. They come in a range of models, from the classic circular dial to easy-to-use soft-touch buttons and backlit displays. You can easily set your preferred temperature with the touch of your hand. The Honeywell Home website has a range of non-programmable thermostats to choose from .
Honeywell Home Programmable Thermostats: These thermostats allow you to set different temperatures for different times of the day. This can help you save energy and money on your heating and cooling bills. The Honeywell Home website has a range of programmable thermostats to choose from.
Honeywell Home Digital Non-Programmable Thermostat RTH5160D1003/E: This thermostat is simple and intuitive to use. It has a backlit screen and basic button functions that make it easy to control the temperature. Once you set your desired temperature, the thermostat stores it in its memory, even during a power outage.
Non-Programmable Thermostats ' Honeywell Home RTH5160D1003/E Non-Programmable Thermostat ' Honeywell Home Might as well look at the programmable ones on their site. Check their customer service if you have an additional question. The above mentioned should work with your setup.
1/15/2024 10:46:15 PM •
Honeywell...
Answered
on Jan 15, 2024
Where is battery on a Honeywell LR95329 Thermostat Base please?
They all hide in the thermostat base.
Load on the contacts is 24 vac standard, 30 volts max. the battery however is a standard AA or AAA Duracell battery, it is not 30 volts.... Those are available almost everywhere, You can pry the front of the thermostat from its wall mount sub base and see the batteries inside... just replace them.
Apr 18, 2017
12/5/2023 4:22:10 AM •
Honeywell...
Answered
on Dec 05, 2023
