20 Most Recent KitchenAid Architect ® Series II KSRX25FT Questions & Answers
Is there a Trick to cleaning the coils on the bottom of Fridge? You can reach the first rows but everything in between there is a problem.
Yes you have to prop it up on blocks and clean it with vacume accessories. You can turn it on it back and clean it but you have to let it stand for 2 to 4 hours after standing it up right before plugging it back in to allow the free on to filter through.
5/27/2014 6:46:30 PM • KitchenAid... • Answered on May 27, 2014
Underside of ice bin freezes up built up with
f9f9b734-83c7-44ff-8864-1aaa9784ca26.jpgW10224328 Dispenser Door Springccde7cf6-a718-42c1-a6aa-4bd5f57dd0ed.jpgThe chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
10/18/2013 12:11:17 PM • KitchenAid... • Answered on Oct 18, 2013
0answers
Do you know what the
25.3 cu. ft.
4/15/2011 2:44:59 AM • KitchenAid... • Answered on Apr 15, 2011
0answers
Air flow at the top little at the bottom
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
7/12/2010 3:04:30 PM • KitchenAid... • Answered on Jul 12, 2010
Not getting cold on both side refigerator
Good day,
The ice maker locks out if the machine is not at normal temperature.
So the cooling system has to be repaired first.
Here is a list of items on a standard refrigerator that would prevent it from cooling.
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
So you need to give us some idea how it is acting.
Is it running ??
Are there any unusual noises and coming from which part of the machine ??
Was the failure instant or over an extended period ??
Is there frost or ice building up in the freezer compartment ??
Please be detailed as possible.
The list above is what a trained service tech would use if he made a service call to the house.
A refrigerator is not a simple device.
3/25/2010 10:41:54 PM • KitchenAid... • Answered on Mar 25, 2010
When i depress the paqddle to dispense ice the
Make sure the ice bucket is fully seated into the space below the ice maker where it rests, if not in all the way, the auger cannot engage and or the switch that tells the auger motor that the bucket is in place will not be triggered.
Good Luck !
3/14/2010 4:06:26 PM • KitchenAid... • Answered on Mar 14, 2010
Fridge side of Kitchenaid isn't cooling like it should
Hi
One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time.
Inspecting the rear wall of the freezer compartment for a frost build up is necessary. If there is a frost coating on it, it is often a sign of excessive frosting beneath it. You may need to remove the evaporator cover panel will actually need to be removed before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too. There is a defrost timer that can also go bad.
Please see these diagrams for more details--
Kitchenaid refrigerater KSRX25FTWH01
Please do accept this solution and revert for further assistance.
Thanks
Rylee
6/6/2009 6:33:43 PM • KitchenAid... • Answered on Jun 06, 2009
2answers
Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
3/20/2009 3:59:10 PM • KitchenAid... • Answered on Mar 20, 2009
2answers
KitchenAid French door refrigerator. How do I repair a non-working water Dispenser on it please?
Troubleshoot step by step and if that fails, resort to a professional: Check the Basics: Make sure the refrigerator is plugged in and receiving power. Verify that the water supply to the refrigerator is turned on. Inspect the Dispenser Actuator: The dispenser actuator is the component that activates the switch to send voltage to the dispenser. Check if the dispenser actuator is damaged. If so, replace it with a new one. I list a procedure for testing this actuator at the end of these basic steps. Frozen Water Tube: Disconnect the water supply tube at the bottom of the door. Blow air through it. If air doesn't pass through, the water supply tube may be frozen. Thaw it out and ensure the freezer is set to the proper temperature (0-10°F) to prevent future freezing. Water Inlet Valve: The water inlet valve opens to supply water to the dispenser. Ensure the water pressure to the valve is at least 20 psi. Use a multimeter to test the water inlet valve for continuity. If it lacks continuity, replace it. Check Water Filter: Remove the water filter and dispense water. If flow increases, the filter may be clogged or incorrectly installed. Replace the water filter if needed. Verify Water Supply Valve: Ensure the water supply valve (connected to the refrigerator) is fully open. If disconnected during service, it might not have been turned back on fully. And now, the testing of the actuator. To determine whether the dispenser actuator in your KitchenAid refrigerator is damaged, follow these steps: Visual Inspection: Look closely at the dispenser actuator. Check for any visible signs of damage, such as cracks, chips, or breakage. If you notice any physical damage, it's likely that the actuator needs replacement. Functional Test: Press the dispenser lever or button as you normally would to dispense water. Observe the response: Does the actuator move smoothly and engage the switch behind it? If the actuator feels stiff, loose, or doesn't move at all, it may be damaged. Listen for Clicking: When you press the dispenser lever, listen for a clicking sound. The actuator should make a distinct click as it activates the switch. If there's no click or an unusual noise, it could indicate a damaged actuator. Multimeter Test (Advanced): If you have a multimeter, you can perform a continuity test on the actuator. Disconnect the refrigerator from power. Remove the actuator cover (if applicable) to access the actuator. Set the multimeter to the continuity (ohms) setting. Touch the multimeter probes to the actuator terminals. If there's no continuity (infinite resistance), the actuator is likely faulty. Remember to exercise caution when working with electrical components. If you're unsure or uncomfortable performing these checks, consider seeking professional repair assistance. Remember to consult your Owner's Manual for specific instructions related to your model. Much of this information comes from the RepairClinic site.
3/17/2024 4:42:35 AM • KitchenAid... • Answered on Mar 17, 2024
KitchenAid Refrigerator Model KSRS25Q. Are Replacement door seals available?
Question edited for a lot more clarity, 'make model (what it is)'. Question moved for correct category. Yes they are, direct or from Parts Suppliers. https://www.google.com/search?q=KSRS25Q+WH11+door+gasket ..
1/4/2024 10:29:11 PM • KitchenAid... • Answered on Jan 04, 2024
KitchenAid refrigerator superba is not cooling. Frizzer is fine
Possibly you r hhermostat in Fridge section gone bad. (if freezer working then most likely (if freezer at top & fridge has Iced up or food in the freezer or fridge Is Blocking the Air vents inside that circulates the cool air flow to Bottom or top, check & listen to see if Fan is working inside freezer /fridge worst case scenario is (if you have a p.c board on top , that could b a Fault there also (then you need a Tech, ).
10/26/2023 4:15:12 AM • KitchenAid... • Answered on Oct 26, 2023
KitchenAid KBFC42fts - light turns on but control panel won't work. I have turned off and back on via the circuit breaker. Is there a reset trick on the control panel?
You didn't say but you need to turn the breaker off for 10 minutes. Best to you.
6/22/2023 1:51:56 PM • KitchenAid... • Answered on Jun 22, 2023
My KitchenAid KFCS22EVMS french door refrigerator is leaking water from the bottom.
I would check the door seals as if not sealing damp air will enter and condense, causing water everywhere.
5/20/2023 7:28:10 AM • KitchenAid... • Answered on May 20, 2023
Hi, Kitchenaid kbfc42fts interior controls and lights blinking no alarms
If the interior controls and lights in your KitchenAid KBFC42FTS refrigerator are blinking but there are no alarms or error codes displayed, it may indicate a problem with the refrigerator's control board or power supply. Here are some steps you can take to troubleshoot the issue:
  1. Power cycle the refrigerator by unplugging it from the electrical outlet or turning off the circuit breaker that supplies power to it. Wait for a few minutes and then plug it back in or turn on the circuit breaker.
  2. Check the refrigerator's power supply by ensuring that the electrical outlet is working properly and that the power cord is securely plugged in.
  3. Check the control board for any signs of damage or corrosion. The control board is usually located on the back of the refrigerator, behind a panel. If you see any damage or corrosion, you may need to replace the control board.
  4. Check the wiring connections between the control board and other components such as the lights, fans, and sensors. Loose or damaged wiring can cause communication issues and blinking lights.
If none of these steps resolves the issue, it is recommended that you contact a professional appliance repair service for further assistance. They will have the necessary tools and expertise to diagnose and repair the problem.
4/12/2023 3:18:20 PM • KitchenAid... • Answered on Apr 12, 2023
No cooling and high pitched noise from KitchenAid fridge
  1. Check if the fridge is level. If not, adjust the leveling legs.
  2. Verify that the condenser coils are clean and free of obstructions.
  3. Check the temperature settings and adjust if needed.
  4. Ensure that the evaporator fan is working properly and not obstructed.
  5. Check the condenser fan for proper operation.
  6. If the high-pitched noise persists, it could be a sign of a failed fan motor or other mechanical issue, and a professional repair may be necessary.
1/29/2023 7:15:09 PM • KitchenAid... • Answered on Jan 29, 2023
Kitchenaid kmhs120ess-10: The bottom handle bracket is loose. How can I disassemble the door to tighten the bracket screw?
Hi, Please remove any facades on the microwave first. This should expose the screws the keep the door on the microwave. Once you remove the door then you can achieve your goal. You might also call kitchenaid to get schematics for the microwave to help you when removing the facades. Thank you.
10/31/2022 10:46:58 PM • KitchenAid... • Answered on Oct 31, 2022
KitchenAid Architect ® Series II KSRX25FT Logo
18 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
trick cleaning coils bottom fridge
  • Refrigerators
