20 Most Recent
Desa International ReddyHeater® R115DT Utility Questions & Answers
I have a RH200T, I
you must switch back to kerosene diesel isnt as clean and wont alow it to lite
1/27/2011 12:56:22 AM •
Desa...
Answered
on Jan 27, 2011
My heater's motor turns, the ignitor heats up but
The air line that comes from the motor/pump needs to go to the front hose barb on you nozzle adapter, and the rear line on the nozzle adapter goes down to the fuel tank.
The pump pressure should be about 5.3 or more so your pump pressure is low and this would cause the unit not to work.
Here is a link to a service manual.
http://www.desaparts.com/hsi.html
Make sure you check the rear plastic cover for any cracks and make sure you are not looking pump pressure.
You can also call our service department at 1-877-475-5660 or contact us at www.allpartsinc.com
12/28/2010 2:44:45 AM •
Desa...
Answered
on Dec 28, 2010
R150B Kerosene Reddy Heater-
Neither of you state the model of heater that is giving you starting problems. many of the motors have an external starting capacitor (relay). If so, you may just need that part, if your heater is equipped with one. On the other hand, many have an internal capacitor , which is not servicable.
12/1/2009 11:14:25 PM •
Desa...
Answered
on Dec 01, 2009
I need someone to come out and service our heater.
If its the knob on the gas valve that shouldn't affect the operation however this part is normally not available to the average consumer and I would suggest you have a technician come out
10/26/2009 1:51:53 PM •
Desa...
Answered
on Oct 26, 2009
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
2/9/2009 9:12:53 PM •
Desa...
Answered
on Feb 09, 2009
Heater will not light
I had similar problems with a older Reddy Heater. I bought a 0-15 lb. gauge and removed a plug on the control end of the heater. Turn on or plug it in and set the fuel line pressure as listed on the data sheet (also listed on the heater).
IMPORTANT. This type of heater will not light if the oxygen level is below safe limits. You need more that 14% to support life. Normal is 21%.
1/25/2009 11:01:46 AM •
Desa...
Answered
on Jan 25, 2009
I have a reddy heat
check for a wire getting piched or pierced by a screw or the cowling. If not look for an air flow pressure switch and be sure it is working.
12/18/2008 9:01:58 PM •
Desa...
Answered
on Dec 18, 2008
Reddyheater r100
the fan must be hitting th upper cowling. see that the fan bracket is fully seated in the cutouts in the lower half of the unit.
12/28/2007 12:52:33 AM •
Desa...
Answered
on Dec 28, 2007
