20 Most Recent
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Questions & Answers
New fridge coming today...
Good day,
If it's being delivered by an appliance company, they know that the machine has to be transported upright. So no. You should be able to plug it in as soon as it's set up.
IF the machine is transported on it's side, then yes, a minimum of 24 hours is necessary to get the oil back into the compressor.
Interior Lights "ON" With Doors Closed
Jane0901. Go to the following web site. Look at the solution section concerning Sears
Normal 0 MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Service flash "sf46-515". I am "DaleCos" and have the same problem. I have reported the probem to Consumer Reports and the Consumer Product Safety Commission. More people need to contact these two organizations. Good luck.
http://www.fixya.com/support/t968825-interior_lights_doors_closed
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
My Kenmore Elite freezer door came off one of its
I just spent the better part of an hour on this. There is a white flange with two phillips screws. If you take this off it is easier to see the mechanism, but you may be able to get it back on without removing the flange. I removed the flange. The mechanism attached to the door has a hook facing up and a smaller hook facing down. There is a hinged metal bar below this. The bar has a hinged piece with a loop on it. Pull the loop up. Now push down on the piece with the hooks ( it has a spring) and hook the smaller hook on the loop. Do this for both sides. Now the door should slide easily into the slots. Once in the slots, push down on the hook piece and release the loop. Push the loop back in place along the bar. Hopefully this does the trick for you, it did for me.
Enmore refrigerator model 795.71013.010 ice maker
michael masters is not giving you the proper info. i realize this is from a few years ago but i have to call out a dumb comment when i see it. he told you how to check a whirlpool ice make rand not an lg style ice maker. that you have with an 795 source refrigerator. sorry the he gave you the wrong info. if after 4 years you are still needing help, please respond and i will help you.
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Ice maker is not making ice
Ted,
The arm should be down. The down position applies power to the control module... when the arm is up power is off. It's the opposite of a light switch.
SG
Kenmore Elite Refrigerator error er dh
Great advice from medeer, I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
Found the green technical data sheets under the refrigerator in a small plastic bag near the front.
My refrigerator is 20 months old, just a few months past the warrentee,
Kenmore elite refrigerator alarm keeps going off
you have to send model number,on some bottom mounts there is a metal striker on the door that hits the switches,sometime that gets bent back,all you have to do is readjust the striker by bending it if screws aren't loose but i don't know what kind of bottom mount you have
Why is ice frozen solid in the bin?
The ice could be caused by a partial thaw such as a power failure. To open bin unplug unit. Get lots of towels and a wet Vac if you have one. The use of these will become obvious shortly. Open the door and put a fan blowing on it, the same type of fan we use when it is hot to cool down. Then wait in time it will start thawing. This would also be a good time to clean it inside, you probably were putting that off. When totally thawed and dry start it up and keep an eye on it for a few days it will probably be ok. If not you have a clean unit to try some of the other suggestions.
