20 Most Recent Panasonic KX-TG5771 Cordless Phone Questions & Answers
0answers
My panasonic phone got wet, what do I need to do?
You need to try Silica Gel Packets to dry out your phone. There was a good article on associatedcontent.com that explains how to dry a wet cell phone, iPods, or any electronics.
You need to place your cell phone in a zip lock bag with Silica Gel Packets. Silica Gel will remove all the moisture from the phone and its components, something air drying will not do!
Just Google "Silica Gel Packets" and you will find several companies selling these products. There is also a web site called: http://www.SilicaGelPackets.com that has them.
Sources:
http://www.associatedcontent.com/article/1028188/how_to_dry_out_your_iphone.html?cat=15
5/19/2011 1:37:37 PM • Panasonic... • Answered on May 19, 2011
3answers
My panasonic Cordless Land line
Sorry we do not have a solution for your problem at this time.
1/15/2011 8:47:13 PM • Panasonic... • Answered on Jan 15, 2011
Dial got locked. password is not known. It is
the default is normally 1111.. and given the fact that you didn't set it then probably that is it. try it in and you may get back if it doesn't work.
1/12/2011 5:43:54 AM • Panasonic... • Answered on Jan 12, 2011
How do you remove the lock from the phone
???Š? ?Š?????????Š ?§?²?§???© ????? ?§????????§?­ ???¬???§?² ?¨?§???§?³?????Š?? kx-tg5771bx ?§?±?¬?????? ?®?¨?±?????Š ?¹???? ?§???§?Š???Š?? [email protected]
2/24/2010 5:38:16 PM • Panasonic... • Answered on Feb 24, 2010
L'appareil ne fonctionne plus
Ok, je l'espère, ma traduction est correcte s'il vous plaît ne soyez pas offensé si elle ne l'est pas.
Ce que vous devez faire est de retirer les piles et l'alimentation électrique d'attendre environ 10 à 15 minutes, puis mettez-les en puissance et sur le périphérique.
Qu'est-ce que la marque et le modèle d'appareil est-il?
1/21/2009 8:59:17 PM • Panasonic... • Answered on Jan 21, 2009
Base not responding
I have the same thing....
1/16/2009 8:05:42 PM • Panasonic... • Answered on Jan 16, 2009
2answers
How do u get your Panasonic house phone working model number is kxtga850e keeps saying no link to base reconnect main base ac adaptor
It sounds like the phone system base station is burned out.
2/3/2024 8:19:25 AM • Panasonic Lands... • Answered on Feb 03, 2024
My phone is always on MUTE. How do I turn that off?
Press the mute button to turn mute off.
12/27/2023 5:21:29 PM • Panasonic Lands... • Answered on Dec 27, 2023
How i can change panasonic kx ts500mxw ring tone
I don't think that is possible on that model of phone. This is a phone with only the basic features and a fixed ringtone.
12/21/2023 9:33:34 AM • Panasonic Lands... • Answered on Dec 21, 2023
Panasonic KX-FLB 852 Call Service 6 problem
See Section 6 (Troubleshooting) Section of Service Manual and Page 118 for remedial action. Troubleshooting Guide; User Recoverable Errors - Panasonic KX-FLB852CX Service Manual [Page 81] ' ManualsLib
11/3/2023 10:16:44 AM • Panasonic Lands... • Answered on Nov 03, 2023
2answers
One Panasonic KX-T7633 Phone Not Showing Caller ID
What did you dial when checking voice mail?
10/23/2023 1:24:07 PM • Panasonic Lands... • Answered on Oct 23, 2023
Panasonic portable phone KX-TGD 530 manual
Panasonic has the manual for the KX-TGD530 cordless phone system with digital answering machine here: https://help.na.panasonic.com/telephones-fax/telephones/kx-tgd530/ . Note: the manual covers several models, including some without the answering machine feature. The current link to the manual is https://help.na.panasonic.com/wp-content/uploads/2023/02/KXTG3712_TG372x_TG373x_TG732SK_TG733SK_TG734SK_TGD43x_TGD51x_TGD53x_PNQX8349YA_ENG_ESP.pdf . I hope this helps. Cindy Wells
10/19/2023 9:30:40 PM • Panasonic Lands... • Answered on Oct 19, 2023
I'm having trouble pairing to a Panasonic su htb 350 from my phone
Refer to Page 27 of user manual of your speaker system (Panasonic Sc Htb350 Owner S Manual (usermanual.wiki)) Follow the procedure given. I hope your issue will be resolved.
9/14/2023 1:44:28 PM • Panasonic Lands... • Answered on Sep 14, 2023
2answers
I have lost the voicemail on my KX-DT343 it now has reorder showing and no message
You can download the manual and "File/Save As" to your Documents folder from here (under "Resources")...
9/3/2023 12:46:32 AM • Panasonic Lands... • Answered on Sep 03, 2023
Panasonic KX-T7433 CO Not Assigned Error
The "CO Not Assigned" error on your Panasonic KX-T7433 handset indicates that the Central Office (CO) line has not been properly assigned to the handset. Since you've mentioned that other handsets in your office can connect to CO-01 without any issues, the problem seems to be specific to certain handsets. Here are a few steps you can take to troubleshoot and potentially resolve this issue:
  1. Restart the Handset: Sometimes, a simple restart can resolve temporary glitches. Try unplugging the handset's power cord for a few seconds and then plugging it back in.
  2. Check CO Assignment: Double-check the CO assignment settings on the problematic handsets. Make sure that the CO-01 line is correctly assigned to those handsets. Follow these steps:
    • Press the "Program" button on the handset.
    • Dial 1 (CO Line Access).
    • Dial the line number you want to assign (in your case, 01).
    • Press the "Auto Dial/Store" button to save the assignment.
    • Hang up the handset.
  3. Reset the Handset: If reassignment doesn't work, you can try resetting the handset to its default settings. Keep in mind that this will erase any customized settings on the handset. To perform a reset:
    • Make sure the handset is not in use.
    • Press and hold the "Program" button while you reconnect the power cord.
    • Keep holding the "Program" button until the handset displays "Initializing..." and then release the button.
    • The handset will restart and return to its default settings. You'll need to reconfigure any personalized settings afterward.
  4. Firmware Update: Check if there are any firmware updates available for the Panasonic KX-T7433 system. Outdated firmware can sometimes cause compatibility issues. Refer to the user manual or Panasonic's official website for instructions on updating the firmware.
  5. Contact Panasonic Support: If none of the above steps resolve the issue, it might be best to contact Panasonic's customer support. They can provide specific guidance based on your model and system setup.
  6. Physical Check: Ensure that the physical connections and cables related to the CO-01 line are secure and functioning properly. A loose connection could lead to communication problems.
Keep in mind that these steps are general suggestions and may need to be adjusted based on the specific model of your phone system and any unique configurations in your office. If you're not comfortable performing these steps yourself, it's recommended to seek assistance from a professional technician or the manufacturer's support team.
8/9/2023 5:52:14 PM • Panasonic Lands... • Answered on Aug 09, 2023
Panasonic KX-TG5771 Cordless Phone Logo
20 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
panasonic cordless land line
  • Lands Phones
