20 Most Recent DISH Network IR Remote Control Questions & Answers
2answers
COMO PROGRAMO LA TV A MI CONTROL REMOTO DE DISH
Hola! mi nombre es Kimberly Escobar trabajo con DISH Network. Para programar el control remoto con su television hay ciertos codigos que se pueden integrar al control para que pueda funcionar con la television estos codigo son diferentes dependiendo de la marca de televisor que tenga. Es importante saver cual es la marca para saber que codigo se va a integrar este link puede ser de mucha ayuda aqui puede encontrar los codigos necesarios y el procedimiento a como integrarlos http://www.dishnetwork.com/SupportSection/remote-setup si tiene preguntas adicionales o necesita mas ayuda por favor contactenos directamente al 1800-333-DISH.
2/24/2024 1:23:00 PM • DISH Network IR... • Answered on Feb 24, 2024
The tv is jammed. Remote
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
12/10/2022 9:36:51 PM • DISH Network IR... • Answered on Dec 10, 2022
2answers
Codigo para televisor TEC
C?DIGO para el tv TEC por favor
10/29/2022 8:47:58 PM • DISH Network IR... • Answered on Oct 29, 2022
4answers
HOW CAN i RESET SAT
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
10/6/2022 6:40:08 PM • DISH Network IR... • Answered on Oct 06, 2022
2answers
I am trying to program
Hello this is Nick Franta from DISH. There are a couple of codes you can try. The following link will provide the available codes we have. You would need to hold the SAT button down until the top 4 buttons light up, enter the code, then #. The SAT button should flash 3 times when the code is successful.
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Let us know if you need further assistance!
4/14/2020 2:05:10 PM • DISH Network IR... • Answered on Apr 14, 2020
2answers
Need dish code for 50" vizio hd tv remote
Consult operating agencies for help to a code for your tv report.
4/9/2020 2:27:52 PM • DISH Network IR... • Answered on Apr 09, 2020
Aeros Universal remote volume not working on dish
It may be a virus in the system , take the system out for scanning and if it continues , get new antena / aerial which capture network with power.
4/9/2020 12:54:53 PM • DISH Network IR... • Answered on Apr 09, 2020
2answers
I can not get the tv 3 off the screen it stays on all the time ,help
Look for an 'I' for info or 'display' button. Exact answer depends on tv make
4/9/2020 12:23:13 PM • DISH Network IR... • Answered on Apr 09, 2020
2answers
Codigos para control remoto DISH NETWORK 2 4.4 IR UHF PRO
Hola! Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. Si tiene preguntasadicionales, sientase libre de contactarme a: [email protected] Kimberly Escobar Social Media Representative DISH L.L.C
12/27/2019 3:16:08 AM • DISH Network IR... • Answered on Dec 27, 2019
Tengo un control dish network modelo 1.5 NDB Y QUIERO PROGRAMAR UNA TV TOSHIBA
Quiero modificar un control dish 1.5 a una tv Lg... Me pueden dar los codigos xfavor
12/12/2019 8:10:19 PM • DISH Network IR... • Answered on Dec 12, 2019
Buenas tardes tengo un control de dvd sony rmt-d197a y no se como subir y bajar el volumen por fi necesito su ayuda gracias
Este control no tiene luces y ning?n c?digo funciona a?n baj?ndose de la internet
10/6/2019 10:51:15 PM • DISH Network IR... • Answered on Oct 06, 2019
Tv remote codes for HCI tv
285,288,269,261. Try these codes. If you wish to get more codes and other details check: http://electrohelponline.blogspot.com/ & http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
5/22/2019 6:33:49 PM • DISH Network IR... • Answered on May 22, 2019
Codigo para programar control a
Ola necesito programar mi control original de pantalla JVC pero no se como
9/24/2018 1:00:50 AM • DISH Network IR... • Answered on Sep 24, 2018
Codigo para programar un tv SEIKI AL CONTROL DE DISH
Hola necesito c?digos para TV Seiki ya que extravi? el manual de antemano les agradesco
9/13/2018 5:32:10 PM • DISH Network IR... • Answered on Sep 13, 2018
9answers
Nesecito los codigos de el
necesito codigos para my tv samsung y panasonic
8/31/2018 7:07:05 PM • DISH Network IR... • Answered on Aug 31, 2018
8answers
Perdi la hoja de codigos
perdi mi hoja del mi control remoto y no lo puedo programar la marca de mi tv es sonic si m podrias ayudar gracia
12/7/2017 9:02:17 AM • DISH Network IR... • Answered on Dec 07, 2017
6answers
Como puedo programar una tv
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a [email protected]
Kimberly Escobar
DISH Network
[email protected]
12/7/2017 9:01:06 AM • DISH Network IR... • Answered on Dec 07, 2017
2answers
Nesesito los codigos para controlar mi tv
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer asisterle proveendole la informacion que necesita. Algunos codigos que pueden ser programados a un televisor Panasonic so los siguientes: 700, 734, 512, 644, and 685. El procedimiento a integrar uno de estos codigos al control para que funcione con la T.V es el siguiente: oprima el boton de T.V localisado en la parte de arriba del control hasta que los demas botones se prendan en rojo, una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo 700#, el boton de T.V deberia iluminarse 3 veces en rojo despues de esto puede tratar el control para verificar que funcione. Este link tambien le puede ser de mucha ayuda aqui encontrara mas codigos e informacion a programar el control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita informacion adicional o mas ayuda por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le ayude.
12/7/2017 8:56:06 AM • DISH Network IR... • Answered on Dec 07, 2017
2answers
Hola mi nombre es jose
Hola mi nombre es Kimberly Escobar con DISH Network lamento mucho que este experimentando este problema. Sera un placer ayudarle y proveerle la informacion que necesita. Para programar el control de DISH Network con su televisor va a necesitar integrar un codigo que sea compatible para el control y la t.v. Ciertos codigos que se pueden integrar al televisor son los siguientes: 678, 156, 520, 505, 654, y 627. El prcedimiento para integralo es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 654#. El botond de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si necesita ayuda adicional puede visitar este link aqui puede encontrar mas codigos y el proceso a programar el control http://www.dishnetwork.com/SupportSection/remote-setup Tambien puede contactarme directamente a mi correo electronico [email protected].
DISH Network
Kimberly Escobar
[email protected]
12/7/2017 8:54:15 AM • DISH Network IR... • Answered on Dec 07, 2017
Have an Element Tv need
Hello there this is Kimberly Escobar with DISH Network, just ran across your post and would like to help by providing you the information you need. To program the remote control to your television we have certain codes that integrate into the remote allowing it to function your T.V. Some of the codes we have for Element brand T.V are 627, 659, and 902 the procedure to integrate them is the following: Press and hold the clear T.V button located at the top of your remote until all the other buttons light up in red, once you see all the buttons lid enter one of the codes above followed by the pound key, for example 627# the T.V button should light up 3 times. After this u can try your remote to verify it works. You can find more information by following our website www.dishnetwork.com here u can find more codes for any brand of T.V and the procedures you need. IF you have any questions or concern please contact us directly we will be happy to assist.
9/30/2017 1:57:38 AM • DISH Network IR... • Answered on Sep 30, 2017
DISH Network IR Remote Control Logo
1,586 questions posted
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • DISH Network Televison & Video
Most Popular Question
como programo la tv mi control remoto de
  • Televison & Video
