20 Most Recent
Motorola Mobility RAZR V3c Cellular Phone Questions & Answers
Recover deleted photos
First thing to note is that the deleted data on the phone will remain there until something new is saved and overwrites it. This might not happen immediately but eventually, after continued use, it will.Either connect the phone straight to a PC using a USB cable (if supplied with the phone) or take the card out and put it in a card reader attached to the PC. You should see memory card shown as a drive letter (like H:) in Windows Explorer.Then try some photo recovery software on the PC. This should recognise the phone or card and then you can scan it using the free download of some good photo recovery software. That will show you what files still exist on the phone or card and what can be recovered.
http://www.asoftech.com/apr/
2/18/2021 9:21:21 AM •
Motorola...
Answered
on Feb 18, 2021
Location of SIM card in Motorola Razr
Are you guys serious....
Verizon & Alltel (which happened to recently finalize the merge) use CDMA. CDMA does not use SIM cards.
AT&T, T-Mobile, etc. use SIM cards - wheter they are 3G networks, TDMA, etc.
10/2/2020 5:07:32 AM •
Motorola...
Answered
on Oct 02, 2020
Texting problem
menu->messaging->settings->All msg->turn on auto erase->ok->turn it off and it should work
2/22/2018 2:13:43 AM •
Motorola...
Answered
on Feb 22, 2018
Hanging up
It should be consistent in both directions, you might try backing up your phone directory and doing a master reset.
2/14/2017 4:00:44 AM •
Motorola...
Answered
on Feb 14, 2017
Phone wont hold a charg and wont turn on
what you have to do is to clean your phone using isoprophyl alcohol i mean you clean the main mother board then you dry it using hair dryer ,after all that try to replace the battery it has reach it death neal the cells inside they are no longer able to hold the charge.advice by dogy.
4/30/2015 2:46:20 PM •
Motorola...
Answered
on Apr 30, 2015
Download texts messages onto computer
You will need to download a software called mobile phone tools to get this done. You will also need a data cable or a bluetooth dongle on your PC so that you can connect the phone. http://www.bvrp.com/ENG/products/
After downloading and installing the above software follow these steps to transfer the msgs to PC.
Open Mobile Phone Tools
Press F3 (for transferring messages from outbox) or Press F4 (for transferring from inbox)
Select messages you want to transfer
Select EXPORT
Choose format/destination. I would recommend txt format as it is real quick.
Hope that helped,
Sai.
7/9/2014 10:47:28 AM •
Motorola...
Answered
on Jul 09, 2014
Does the AT&T network support the motorola Razr V3m phone?
Ya sure you can use AT&T sim in Motorola razr v3m only if it is unlocked one .Else if the phone is locked to some other network provider then it wont accept other network sim until you unlock it .You can easily unlock it using code .You can purchase code from sites like
WickedUnlock.com they are rendering unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ...
5/19/2014 5:10:33 AM •
Motorola...
Answered
on May 19, 2014
Can The AT&T network run on a Motorola Razr V3m phone?
Your Motorola Razr V3m phone is free of any network lock,it will be run on AT&T network.If it's network locked one means,you will need to unlock it.You can unlock your phone by network unlock code.You can get an unlock code from your service provider or else try to buy an unlock code from any one of the online unlocking service provider like
Mobile-Unlocker.com Here you can unlock your phone at low cost.
5/13/2014 7:12:07 AM •
Motorola...
Answered
on May 13, 2014
Can transfer pictures from my Razr v3 to my computer and visa versa
Your razor phone will connect to your pc with updated software from motorola Don't worry it is free. after you download the software run the program then connect your phone with the phone powered off, then turn on your phones power, it takes a minuet for the phone to connect to the program then your computer should recognize the phone. Need more help you can email me at
[email protected]
12/2/2013 6:02:45 PM •
Motorola...
Answered
on Dec 02, 2013
