20 Most Recent
Sony Ericsson W550i Cellular Phone Questions & Answers
MOBIL PHONE
try to update your phone software. download software update application from sonyericsson website.
My phone contacts in my
The only way to restore your phone contact is if you have previously created a backup of your contacts otherwise there is no way to restore your contacts. But if you have created a backup previously then you would just use the previously created backup to restore your contacts.
Spy bluetooth software for w550i
nice..truly impressive spyingg!!!
k im also from india...
i cant assure u de exact soft ware...stil u'l get it if u searc here
www.getjar.com
if u don get do tell me..
ne thing els do tell me..n plz plz do rate me..
cya
Missing weight for seth thomas metronome
I used a Wittner weight on my old Seth Thomas and it worked just fine. Calibration was very close out of the box. You can get these for less than a couple dollars if you look around.
Insert correct sim card
Are you getting Sim card not accepting error message? If it is so then your Sony Ericsson W550i is locked to a particular network. To fix this you have to unlock it. Use unlock code to unlock your mobile from its network lock. To get the code you need to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:1)Go to Options>status2)Find IMEI on the back of your mobile, behind the battery.3)Type *#06# and press call button. It will display your IMEI number.You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site
Mobileunlocksolutions.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Game installation: Sony Ericsson W550i Cellular
1. Connect your W550i phone to your PC using the USB cable.
2. Use it in File transfer mode.
3. Go to it's Others folder on the Memory Stick that just appeared over at the My computer screen. (probably called PHONE_CARD or something similar).
4. Copy the .jar files from your PC to the Others folder on the phone's stick.
5. Disconnect your phone properly (safely remove hardware) and allow it to restart or return to Phone Mode.
6. They should appear in your games folder. Otherwise go to your files on your phone (File Manager) and go to Others. and open the files.
Please let me know if this had helped you out. Please rate.
Greetings,
DarkNeogen
Phone lock code
Slide the PHONE up to reveal the keypad.
2Type in your four to eight digit PIN and press "OK." If you have not set a UNIQUE PIN, enter the default PIN code that is set by your wireless carrier. (Normally "0000" or "1234.") If you receive an "Incorrect PIN" error, enter the default PIN twice more. "PIN Blocked" will be displayed.
Contact your wireless provider to request the unique Personal Unblocking Key for your device. In most cases, you will need to verify your wireless account information to obtain the code.
4Type in the PUK code and press "OK."
5Type in a new PIN code--the code can be four to eight digits. Press "OK." Re-enter your PIN to confirm and press "OK." The device is now unlocked.
- Unlock Phone
- 6
Slide open the phone to reveal the keypad.
- 7
Enter in your four to eight digit lock code. If the code has not been altered, it will be "0000."
- 8
Press "OK."
Sponsored LinksGOD BLESS YOU
Video playback
please check ur video format is it eigther avi, mp4, 3gp etc.
ur phone is compatible only with 3gp video format so please download first 3gp formatted video clips. and u can send video clips only under 100kb size.
