20 Most Recent RCA RCR311S Remote Control Questions & Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
RCA RCR311S... | Answered on Sep 18, 2014
To program the remote, press and hold the component key (TV, for example) that you want to program. Then when the On-Off light turns on and stays on, enter the first code for the device you want to the remote to control. Then release the component key and check if the code controls your device. (Some codes may only control some functions so try all the keys you will want to use before deciding that you have a good code.) If the code doesn't work, repeat the steps from holding the component key.
Panasonic TV codes to try 1003, 1054, 1055, 1062, 1109, 1130, 1170, 1248 .
The RCR212W manual is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RCR312W_DOC_OM.pdf .
Please note that if your TV is newer than your remote, you may need a new universal remote. The codes in the remote are limited to those for devices released 6 months or more before the remote was programmed.
I hope this helps.
RCA RCR311S... | Answered on Oct 11, 2011
Step 1: Press and hold the device key (TV, VCR, SAT, etc) you wish to program. The illuminated ON/OFF key(*) turns on and remains on. If you release the device key at any time during the Direct Code Entry procedure, the illuminated ON/OFF key blinks 4 times, and the process is exited.
Step 2: While holding down the device key, use the number keys (0-9) on the keypad to enter your equipment's code. While you are pressing the numbers, the illuminated ON/OFF key turns off.
Step 3: After the 4th number is entered, the illuminated ON/OFF key turns on. At this time, release the device key. If the illuminated ON/OFF key turns off, you have entered a valid code and have followed the correct procedure. If you enter a code that is not in the Code Lists or you do not follow all of the correct steps for Direct Code Entry, the illuminated ON/OFF key blinks 4 times when the component key is released - an indication that a programming error has occurred. In that case, repeat the process from Step 1 and try the next code in the list.
Step 4: To confirm that remote is programmed with the correct code for maximum functionality, test it. If some of the features of your equipment do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions as different codes can provide different levels of functionality.
* some models like the RCR450 have a LED indicator light in place of the illuminated ON/OFF key.
i hope this would work for your remote controll please contact me if it does
RCA RCR311S... | Answered on Aug 16, 2011
Try these codes for Quasar TVs:
1003, 1054, 1055, 1070, 1109, 1170
Codes can be found here.
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Basically, try holding the TV button, the on/off button should light up. Then press the digits for the code one at a time. If the code is accepted, the on/off button should go off. Finally let go of the TV button. Now try operating your TV.
RCA RCR311S... | Answered on Mar 27, 2011
I can help you reprogram your RCA RCR311ST for all your Orion TV. The folks at RCA did away with a code search button for this model and you must press a combination of buttons to setup programming more.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up for your Orion TV on this remote's device code list.
I hope that helps.
RCA RCR311S... | Answered on Apr 10, 2010
Tip
RCA Universal Remote Code Entry
Models RCR312W - RCR311BN - RCR311BIN
RCR311SN - RCR311STN
Would you like help entering the code to program your RCA Universal Remote? You can look up the codes for your remote on this list.
Here are the steps to enter the programming code into your RCA Universal Remote:
  1. Manually turn on the device you want to control.
  2. Find the Code List. Locate the section for the type of device you would like to control and find your brand in that section. Write down the code(s).
  3. Press and hold the device key you want to program. The on/off key light comes on.
  4. While holding the device key, use your other hand to enter the first five digit code for your brand from the list. The on/off key light goes off after the first digit.
  5. When finished entering the code, keep holding down the device key and look at the on/off key light. If the light is on, you have successfully programmed your remote. If the light blinks four times and turned off, you have entered a code number that is not in the code lists or have missed a step in the code procedure. Try the previous step again.
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
Tip
RCA Universal Remote Code List
Would like to program your RCA Universal Remote, but have lost your code list?
The RCA RCR311S code list can be downloaded here.
I hope that helps.
Tip
RCA Universal Remote Code Search
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
yes there is a video on you tube how to program a universal remote
RCA RCR311S... | Answered on Feb 27, 2010
Please check & ensure the infrared is emiting from the remote control. Though we cant see this infrared beam with bare eyes, there is a trick to do so in http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html Most of the problems is weakened infared beam. Replace the batteries when needed. Hope this fix the remote control problem.
RCA RCR311S... | Answered on Jan 24, 2010
This is the link to get the manual:
http://audiovox2.info/docs/rca_acc/man/RCR311S_DOC_OM.PDF
This is the link to get the Code for the manual:
http://audiovox2.info/docs/rca_acc/man/RCR311S_DOC_OTHER.PDF
I hope this helps..
RCA RCR311S... | Answered on Sep 13, 2009
There are a ton of codes you can try for RCA TVs:
1000, 1003, 1005, 1006, 1019, 1054, 1096, 1098, 1099, 1100, 1101, 1102, 1103, 1129, 1179, 1188, 1190, 1203, 1240, 1252
You can find codes here:
RCA RCR311S... | Answered on Jun 07, 2009
For codes, check here:
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
RCA Televison &... | Answered 6 hours ago
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
In general the TV is not receiving any input. The fact that you lost HDMI and VGA earlier suggests that there is a breakdown in the input circuits.
Best guess, replace the main board. Symptom doesn't seem to indicate Power supply or TCon board
https://www.a2zelectronicparts.com/products/view/82546
RCA Televison &... | Answered on Nov 09, 2019
RCA RCR311S Remote Control Logo
20 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
need code rcr311s universial remote
  • Televison & Video
