20 Most Recent
Nokia 5200 Cellular Phone Questions & Answers
How do i reset the security code?
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Hang
Simple reason when two or more work come means it will hang, like playing game.
Phone memory protected for nokia 5200
Dear
Please Check That u have set any security for phone memory
You can check by entering into setting menu - security setting - security code
It will shows Phone & Memory Option , Select Phone Option
It will ask for security code - enter default security code 12345 if u not have changed it
Then Option Shows ON & OFF Turn It off & ur phonebook will be unblocked
Please revert ur comment
I am using NOKIA-5233 and
Packet data connection unavailable is a carrier error that means either the amount of web access purchased on the account has been exceeded or that your internet connection needs to be reset. Either way you need to contact the carrier and report the problem for them to reset your internet counter in their system and then turn your phone off and restart it to clean the problem.
Nokia 5200 Restriction Code
You can get the restriction code for your Nokia 5200 from your service provider or from any reliable online sites!!! I would suggest
simpleunlocking.com , here they provide perfect codes at reasonable price!!!
I forgot my nokia 5233
Iam Benson. I forget my Nokia 5233 phone lock code my imei no 359287046388096 plz help.
When i open the web
Hi, i solved your problen.Take your phone and go to manu>settings>configuration>personal configuration settings>and press options>add new>web , and creat a new settings and set to active..Or, contact service providers..
