20 Most Recent Motorola Mobility L6 Cellular Phone Questions & Answers
moz-screenshot-1.jpgmoz-screenshot-2.jpgHI dude,
to bypass the security, i hv got a trick.
When u r asked for security code,
press menu button(above the directional keys) for 3-4 seconds. if u hv done properly the gap for 4 digits will be changed to 6 digits slot. Now enter 000000 (six zero). now u will bypass the security code. By same process u can change or reset security code from settings.
Looking for ur kind feedback. Dont forget to Rate my solution too.
Be sure to post a clarification request after ur problem is solved.
SAJAN(sajwhat@hotmail.com/sajwhat_2003@yahoo.com)
Motorola... | Answered on Oct 13, 2018
At HOVR you can find all the top rated and most popular Motorola mobile java games for free.
All you need to do is select your Motorola cell phone from the list and choose from a great selection of free Motorola mobile games and apps for your phone.
You'll find a long list of free Motorola mobile cell phone games that are ready to download and play. You can easily download these free Motorola cell phone games via SMS or via WAP.
Please rate my solution.
Thanks For contacting Fixya.
Motorola... | Answered on Jun 28, 2017
its ur mobile application problem. so u need reinstall ur mobile application.
Motorola... | Answered on Feb 08, 2017
switch of your bluetooth delte your freind from your bluetooth list turn on bluetooth again....and let your freind connect to you hopefully this should work because i had the same problem with my phone
p.s make sure on your phone your phones visiblty is on :D
hope this helps
Motorola... | Answered on Jan 13, 2017
just do a master reset on the phone that should correct the problem
Motorola... | Answered on Oct 17, 2016
Next time you call motorola, ask them to change your phone and not the battery. Your phone has the issue. The battery is being used up due to some error on the phone itself.
Motorola... | Answered on Aug 09, 2016
Hi Kumar,
In this link you will find the steps to perform a Master Reset or Master Clear so you can fix your device.
Regards,
Maya
Motorola Support
Motorola... | Answered on Apr 11, 2016
if you have an internet plan on your phone you can send that file throught it. And if your phone has bluetooth and PC with bluetooth you can sync both device without problem. Or if your phone has an external memory capable (SD,MS,Pro,MMC,XD, etc..) put that kind of memory on your phone and save to that external and transfer it to your PC.
Motorola... | Answered on Jun 16, 2015
By delete, do you mean, completely hide this? If so, all you need to do is turn your Mobile network data off, or in other words, your 3G.
Motorola... | Answered on Jun 01, 2015
When setting your unlock code, did you also set a security question?
Motorola... | Answered on May 30, 2015
Have to do a factory reset for that, sorry to tell you that but its the only way to fix it.
youneed to set your apn in order to get or receive texts,here is sprints settings in pics,the rest i will post a link for,
Cellular APN Settings Best You Can Get
Motorola... | Answered on Mar 27, 2015
The IMEI number is on a label under the battery. Remove the battery to get access to the label.
OR
Normal 0 You can also get the IMEI number by entering this on your phone
*#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
Motorola... | Answered on Feb 19, 2015
It's stored automatically but can't be exported.
Mark
Motorola Support
Motorola... | Answered on Feb 10, 2015
Battery may be bad and may not hold a charge. Look for a replacement battery.
Motorola Support
Motorola... | Answered on Jan 11, 2015
Hi Anonymous
In this case you will have to get in touch with our support team so they can assist you with the reset, since there is no external way to perform it. You can contact our support team here: http://bit.ly/ContactUs-Locate
Regards,
Gaby
Motorola Mobility
Motorola... | Answered on Oct 09, 2014
Please ensure you have selected the correct device.
Contact us if this is really about a mobile phone.
Http://www.Motorola.com/support
Mark
Motorola support
Motorola... | Answered on Aug 24, 2014
Motorola Mobility L6 Cellular Phone Logo
1,421 questions posted
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Cell Phones
Most Popular Question
unlock code
  • Cell Phones
